grinding door locks
Old Aug 9, 2014 | 01:23 AM
marioc89's Avatar
5th Gear
grinding door locks
Hello everyone! I'm new here and I would really like to gather all kinds of knowledge from this site.
So my problem is that, when I go to lock the car, it gives a grinding noise on all four. Does anyone have a solution for this or had problems of this nature before?
Old Sep 1, 2014 | 03:56 PM
cwelsh214's Avatar
Sounds like the actuators are bad. Seems odd they would all go out at the same time. Are you sure it is all four? Even if it is just one it can be very loud.
Old Sep 1, 2014 | 10:55 PM
main70072's Avatar
Rubber 'stops' inside the actuator worn or torn off. Seems to be common as the car ages.
Old Oct 13, 2014 | 07:12 PM
Whitey_1997TL's Avatar
You can disconnect the drivers lock actuator behind the door panel. The drivers door is the usual culprit. The lock system thinks it's still unlocked and that's why it keeps trying to lock.
Old Oct 17, 2014 | 01:43 AM
bayareacl's Avatar
3rd Gear
man i had this problem in my old 3.2.that sound is so Fckn annoying, luckily it was only the rear right.wouldnt want to imagine what all four would sound like. Actuators for sure,good luck
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
