Error codes on my 3.2
Old Jan 29, 2006 | 01:38 PM
Altitude's Avatar
Today I shorted the blue wire plug under the glovebox.
Looking to my CEL nothing BUT my ABS light flashed
5-3 was one code
1-3 the other.
would anyone have the problems it detected?
Old Jan 29, 2006 | 03:59 PM
TexasHonda's Avatar
Code 53 is modulator pump stuck ON.
Modulator relay could be stuck closed causing pump to be hot when it should be cold.
Code 13 is LF wheel sensor fault (short or open). Check sensor wiring and sensor resistance (550-850 ohms). You might also clean the sensor and lugs on the axle that sensor monitors. Dirty lugs or dirty sensor can degrade sensor output.
A Honda shop manual for your model will help your repairs.
good luck
Old Jan 29, 2006 | 04:14 PM
Altitude's Avatar
Thanks TeaxasHonda.
Agreed on the manual....gotta get one ASAP...
Jamus22
Jun 11, 2023 10:08 AM
Pham Alvan
Mar 16, 2016 09:17 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
