Engine dies...
Old Dec 20, 2007 | 05:18 PM
TLBaller's Avatar
Engine dies...
I just replaced my spark plugs and ignition wires. Just today, I noticed my car dies on a slope or when I get out of the REVERSE gear. After i shift it out of Reverse and into D4, my engine dies.
Also my car was already on D4 and was on a slope waiting to get out onto a main road, after waiting for awhile, the car dies on its own. I put it back in park to restart and it starts right up. The radio and light still works and I have not taken off my terminal battery so I know its not loose. I did however cleaned off the dry foam thingy on the terminals using a brush but thats about it.
What could be the problem? one of my ignition wire was a short so im thinking either the man gave me the wrong ignition wire for my 2.5 or i put it on wrong but im sure i put it on right. the short wire is the only one that does not go into a spark plug. it goes into some big round plug in front of my car battery. Could this be the problem?
Old Dec 20, 2007 | 06:21 PM
Go90go's Avatar
大日本帝国
Do you have a check engine light on? Make sure the plugs are gapped properly, too.
~Cheers~
Old Dec 20, 2007 | 10:41 PM
TLBaller's Avatar
yeah the check engine light is on. it came on when i heard my engine "whine" as i accelerate. i think its a belt..or need to change oxygen sensor. im POS is falling apart.
Old Dec 20, 2007 | 11:43 PM
Go90go's Avatar
大日本帝国
Is your charging indicator on? Damn, if only you were closer, I could help you diagnose it!
~Cheers~
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
