Drive side headlight bulb replacement?
Old Apr 19, 2009 | 05:27 PM
Myka's Avatar
5th Gear
Ok, haven't had to do this b4. I've got a 96 tl 3.2. Do I need to remove the windshield wiper fluid reservoir and/or the coolant overflow reservoir to get to it? If so, any trick to pulling them?
:t omato::tom ato:
Old Apr 19, 2009 | 11:02 PM
TLin401's Avatar
'13 Hyundai Sonata
It is loose already so you can pull it right out. There is a clip that holds the line in so just unattach that and you should be fine.
Old Apr 20, 2009 | 07:15 AM
KaMLuNg's Avatar
on the 3.2TL you need to remove the coolant overflow resevoir to access the back of the headlight... just unscrew the cap and pull the tank straight up... that should give you access to the bulb cover... if you need to do the fog lamp, you will need to remove the battery that is right next to the overflow tank...
Old Apr 20, 2009 | 08:05 AM
desired_speeds's Avatar
I've actually managed to do the foglight without removing the battery, but I have to admit, it was a tight fit.
TLrascal
Aug 3, 2018 11:00 PM
HairyMonkey019
Apr 22, 2016 10:50 PM
nanos
Nov 12, 2015 08:41 PM
theinsvnity
Sep 10, 2015 10:22 PM
Phambam12
Sep 6, 2015 06:57 PM
