Door lock only works manually
Old Oct 21, 2011 | 01:08 AM
praxis83's Avatar
7th Gear
Hey Guys,
I'm new around here and to the whole fixing-my-own-car thing, so forgive if I ask some dumb questions from here on out. I've tried searching for the answer to this question on here, but haven't quite found the reply I was hoping for, so I just figured I'd post it. Thanks in advance to anyone who can help me shed a little light on it.
Anyways, here goes: I just recently purchased a 1996 TL 2.5. The rear passenger door lock works if you lock it and unlock it yourself, but doesn't if you use the power door lock feature from the front seats nor the key entry. Is this a problem that can be solved easily like a loose bolt, or do I need something like a whole new actuator? If I do, how much does one of those usually run? Thanks so much guys.
Old Oct 21, 2011 | 09:53 AM
96TL_X's Avatar
I would spray some WD40 on the switch
Old Oct 21, 2011 | 10:55 AM
96TL_X's Avatar
NVM on this! I read it wrong
Old Oct 21, 2011 | 11:11 AM
praxis83's Avatar
7th Gear
Its cool. I appreciate any help I can get. I may just try replacing the actuator to see if that'll work since I found one that is relatively inexpensive. However, it says its for the FRONT passenger side. Is it not the same part for the REAR passenger? All four doors use a different actuator? Thanks again guys.
Old Oct 21, 2011 | 08:58 PM
KrayzieDxC's Avatar
Khmer Pride
should be the same
Old Oct 22, 2011 | 10:52 PM
praxis83's Avatar
7th Gear
Thanks for the input guys, I appreciate it. I figured out an alternate solution.
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
lland
Oct 4, 2015 04:47 PM
acurajj
Sep 19, 2015 03:47 PM
ahsm
Sep 9, 2015 08:35 AM
