dome light replacement procedure required
Old Oct 8, 2007 | 09:11 PM
deepsruns's Avatar
3rd Gear
Hello, I need to replace the dome light bulb in my Acura 2.5TL as it has fused. Tried doing it but could not get the component off from the roof.
If anybody can provide a stepwise procedure to replace the dome light, it will be a great help.
Thanks.
Old Oct 8, 2007 | 10:40 PM
lg562's Avatar
use a flat head screw driver and pry it out from the backside (closest to the rear seats). its only 2 clips, it should come right out. make sure your switch is clicked to OFF when you take the bulb out, im not sure what would happen if it were to be on ON.
mada51589
Jan 9, 2025 04:40 PM
wusty23jd
Sep 24, 2015 11:41 AM
brjones9
Sep 3, 2015 07:30 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
