dome light replacement procedure required
Hello, I need to replace the dome light bulb in my Acura 2.5TL as it has fused. Tried doing it but could not get the component off from the roof.
If anybody can provide a stepwise procedure to replace the dome light, it will be a great help.
Thanks.
Thanks.
use a flat head screw driver and pry it out from the backside (closest to the rear seats). its only 2 clips, it should come right out. make sure your switch is clicked to OFF when you take the bulb out, im not sure what would happen if it were to be on ON.
mada51589
05-03-2022 08:54 PM
wusty23jd
09-24-2015 11:41 AM
