DIY Head Gasket, 3.2
Old Jan 21, 2014 | 03:31 AM
ppdmostwanted's Avatar
5th Gear
I will be replacing my head gasket. Is there anything else you fellas think I need to consider replacing as well? Do i need to replace intake manifold and exhaust gaskets?
2 felpro headgaskets
import direct water pump
gates powergrip timing belt
felpro valve cover gasket set
Long time follower, first post.
Old Jan 21, 2014 | 04:04 AM
5th Gear
timing cover gasket set
Felpro egr valve gasket
misc o-rings
intake manifold gasket set
exhaust manifold gasket set
egr pipe gasket
liquid gasket
Old Jan 21, 2014 | 11:31 AM
9632tl's Avatar
Radical Member
Sounds like you've got most of it covered
Old Jan 21, 2014 | 11:33 AM
5th Gear
Do the head bolts need replacing?
Old Jan 23, 2014 | 10:24 PM
faheyd's Avatar
4th Gear
I couldn't find that in the FSM so I guess it's not needed for the acura.
Also, make sure you drain coolant and take the head bolts off in the order stated in the FSM to prevent warping.
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
