dead
Old Mar 6, 2011 | 09:27 PM
shawnathon81's Avatar
dead
replaced distributor and wont start. how do you adjust the timing or what do i do
Old Mar 6, 2011 | 09:31 PM
turns over has fuel but no spark
Old Mar 6, 2011 | 11:42 PM
desired_speeds's Avatar
pull a plug out and shove it into the boot. ground the tip of the plug and crank, see if it sparks. recheck the firing order since you may have put back the wires wrong.
Old Mar 7, 2011 | 10:01 AM
firing order 1-2-4-5-3
do i hook the cylinder 1-2-3-4-5 to the distributor 1-2-4-5-3 ?
Old Mar 12, 2011 | 11:27 AM
TexasHonda's Avatar
Match numbers on distributor to cylinders. No. 1 is all the way forward on engine and others follow.
good luck
SidhuSaaB
May 30, 2020 12:40 AM
knight rider
Mar 4, 2016 08:59 AM
DerrickW
Nov 15, 2015 05:52 PM
Houston
Oct 8, 2015 01:27 AM
kb1rl
Sep 30, 2015 10:17 AM
