D4 Light
Old Jan 1, 2009 | 10:09 PM
datroyster09's Avatar
D4 Light
How do you you replace the D4 light in the instrument panel?
Old Jan 1, 2009 | 10:31 PM
TLin401's Avatar
'13 Hyundai Sonata
You have to take the dash out and once you get access to the back of the gauges then you can just take the bulb from first or second gear since those aren't used often and just switch it with the D4 and the light will come back on.
Old Jan 1, 2009 | 10:48 PM
tmnhs81's Avatar
Take the dash out means take the cover around cluster out then take the cluster out(be carefull). Good Luck.
Old Jan 2, 2009 | 08:13 AM
TLin401's Avatar
'13 Hyundai Sonata
Yes be careful. I broke that dash piece yesterday and now I have to find another piece to replace it.
Old Jan 2, 2009 | 11:47 PM
Ok, Thanks alot!!!
Old Jan 3, 2009 | 04:22 PM
Mandy's Avatar
98 3.2 Flamenco Black
Pics would be good....
Old Jan 4, 2009 | 12:14 AM
tmnhs81's Avatar
Good luck finding one. I broke mine, drove my car around with broken piece for 5 months.
Old Jan 26, 2010 | 11:11 AM
Mandy's Avatar
Where's our DIY on this?
Old Jan 26, 2010 | 06:04 PM
TLin401's Avatar
'13 Hyundai Sonata
You take the dash piece out around the gauges.
There are 4 screws that you need to take out (2 near the steering wheel under the black flap and 2 on the inner part of the black piece of the dash).
Then slowly take out the dash.
After you take out the dash, remove the 4 screws, then disconnect the gauges, and then you can move the bulbs from the gears around.
Old Jan 27, 2010 | 09:13 AM
Mandy's Avatar
Great thanks, I think I got it! Will do it shortly!
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
