Common First Gen TL Problems
Old Sep 14, 2004 | 03:59 PM
  #121
Ken1997TL's Avatar
Not all 4 cylinders are inline. What do you call the Subaru engines?
They're horizontally opposed, 'flat' or 'boxer' engines.
Old Sep 14, 2004 | 04:07 PM
  #122
Cornflake's Avatar
Reppin' the T-Dot!!
Originally Posted by Cornflake
Spooky, don't take this the wrong way cause I'm not trying to put you down at all honestly, just trying to educate you so that you will sound proper talking about your car. The term "V" when refering to an engine refers to the cylinder layout. Yours is actually an I5 or INLINE 5 V's typically come in 6 and 8 cylinders, with 4 and 5 cylinder car engines being inline (there are also BOXER 4 cylinders where the two banks of two cylinders are horizontally opposed, but there are only a few of those around). Anyways, that's enough of my long windedness. Is that a word?
I see a note in there about Boxer engines.... You don't ???
Old Sep 14, 2004 | 06:37 PM
  #123
I've had mine for over a year so far these are the problems I've had or noticed:
STARTER (replaced)
driver side window squeaks (remedied by waxing both sides)
fan stays on (I guess this is normal for the 1st Gen TL)
AC smells (This is a problem for all Honda cars)
Limited Aftermarket parts
Old Sep 14, 2004 | 06:53 PM
  #124
spooky3ce's Avatar
Swift 3 B-A-N-G-E-R
STARTER (replaced)
A lot of 1st Gen TL's have the starter problem... what is the first symptom of a starter problem...??? because my starter might be going out... sometimes it locks up and won't let me turn the car on w/o moving the shifter a bit sometimes... or the key, i'll leave it a bit out so it can turn the starter... if i put the key all the way in... she won't start... Just a quick question...
Old Sep 14, 2004 | 08:19 PM
  #125
Ken1997TL's Avatar
I was responding to wolfpack Bill
Old Sep 14, 2004 | 08:21 PM
  #126
Ken1997TL's Avatar
Hmmm sounds strange. More likely a bad ignition switch if it involves the key or shifter. It thinks the car is in something besides neutral or park.
The bad starter is when it makes a loud "click" and then absolutely nothing. Basically, the starter contacts have lost their copper and are hammering away uselessly.
Old Sep 14, 2004 | 08:35 PM
  #127
WolfpackBill's Avatar
TL no more!
Hmm...true. Never thought of that. But Suburus are never in my mind. I only like Hondas, Nissans and Ford trucks. LOL...
Old Sep 15, 2004 | 07:53 AM
  #128
Cornflake's Avatar
Reppin' the T-Dot!!
Fair enough.
Old Sep 15, 2004 | 11:10 AM
  #129
I had the same problem. The starter just won't turn. I would make several attempts before the engine would finally turn. After a couple of months, it got worst so I finally gave in and had the starter replaced.
Old Sep 23, 2004 | 01:09 AM
  #130
zimzamman's Avatar
5th Gear
My car alarm is acting up also...once this month, twice last month, while at work....I don't lock my car at work; but the alarm went off maybe 5 or 10 minutes after I walked away; I thought it would go off by itself after 30 seconds, but it didn't. I used the remote to shut it of (unlock / lock), and put the key in the driver's door another time...luckily it doesn't appear to randomly go off when the car is locked....
Otherwise, the normal D4 light (replaced with D1; as mentioned, this should be fixed because it is used as a transmisson warning light);
I have 112,000 on the original timing belt, getting ready to replace the belt / water pump (I had 134,000 on the 94 Legend 3.2 before changing the belt, just for info);
Window wind noise, fan remains on when warm after turning off the car (I guess others see the same thing);
Transmission is smooth, 20-22 mpg all times (80 mph tirps with ac, city driving, etc)
CD player is POS (bought 3 units from e-bay to get one that works reasonably well, just to keep original look, but ready to switch to after market unit)
1997 3.2 premium, green, 112,000
Old Sep 24, 2004 | 05:51 PM
  #131
SurfingScotty's Avatar
2007 6SMT Type-S
If you want to keep the stock look, but want a better CD player, look on ebay for a '00-'03 stereo. They fit just the same, but read CDs better than ours. I had the same issue, wanted to stay stock, but gave the head unit to my brother-in-law (for his '89 Legend) and bought a tight Eclipse deck. Obvioulsy not stock, but looks smooth none the less...Doesn't look all retro teenagerish.
I don't know about the new '04 TL's or any other model for that matter. Haven't been over to the local dealer to stroke them yet.
Old Sep 27, 2004 | 03:12 PM
  #132
Colt45's Avatar
B A N N E D
here we go heh
d4 light burnt out
struts blown
chrome peeling off door lock
spring in both passanger side door handles
cd player just ejects cd as soon as you put it in
starter went out
transmission went out
exhaust rusted off
windows whistle from air
keyless entry goes off occasionally when you unlock the doors
trunk leaks massively for no reason
windows go out of track when you close doors sometimes
steering wheel leather wore down
o2 sensor went bad
passanger tweeter blown
beater status. hehe
Old Sep 28, 2004 | 09:07 AM
  #133
2007 6SMT Type-S
Originally Posted by Colt45
here we go heh
d4 light burnt out
struts blown
starter went out
exhaust rusted off
o2 sensor went bad
beater status. hehe
damn...how many miles do you have on your ride??? That is a ton of problems. What year/make?
Old Oct 14, 2004 | 03:41 AM
  #134
spooky3ce's Avatar
Swift 3 B-A-N-G-E-R
Continued...
I'd like to add to my list...
20. C/V Boots... they saw that one of them were blown/torn when installing my new 18x7.5's and there was grease all over my stock rim and the wheel well... so instead of letting it be and have to change the bearings on my "axel"... just re-grease the suckers and get new boots...lol...
21. Broke fuel gauge (note: my fault) lol... bought new one for $89.83... will take pics of install... including glow gauges...
22. Because of problem #21 my speedometer and tach/RPM Gauge aren't working... maybe not making correct contact... temp. gauge is working perfectly...
I'll add more as they come... lol... or until 2.5 TL RIP... ... ***knocks on wood***
Old Oct 24, 2004 | 03:09 PM
  #135
nick919's Avatar
4th Gear
1. slow windows
2.check engine light
3. wont play cds
Old Oct 24, 2004 | 03:13 PM
  #136
UnsanePyro's Avatar
Registered Driver
nick, the check engine light is prolly on for a reason, should have the codes pulled somewhere and see what is up.
the windows i hear you can grease the tracks, havn't tried yet, going to this week hopefully
the cds, does it not play them at all, or just picky? I know mine won't play burnt CDs, and on regular CDs it has problems selecting different tracks.
  #137
nick919's Avatar
4th Gear
how do you change your rear oxygen sensor, please help
Old Oct 24, 2004 | 03:18 PM
  #138
nick919's Avatar
4th Gear
do you know how to change the rear oxygen sensor
Old Oct 25, 2004 | 08:53 AM
  #139
TL no more!
Hmmm...interesting. My stock system seems to take all of my burnt CD's.
Old Nov 14, 2004 | 10:14 AM
  #140
esCarbonie's Avatar
enjoy it while it lasts!!
Old Nov 17, 2004 | 02:09 PM
  #141
AApero's Avatar
8th Gear
D4 light out
Day lights not working
High beam light out
any one else having problems with day lights and high beam
Old Nov 17, 2004 | 02:30 PM
  #142
UnsanePyro's Avatar
Registered Driver
What do you mean day lights? The yellow fog lights? They only come on if you turn the button on and your headlights are on.
And the high beam light in the instrument cluster?
Old Nov 17, 2004 | 07:20 PM
  #143
TL no more!
Day Time Running lights. It is being discussed on another thread.
Old Nov 18, 2004 | 07:59 AM
  #144
AApero's Avatar
8th Gear
Day lights in Canada we have day lights witch means when the car is started they automatically come on and the
high beam light in instrument cluster is not working
Old Nov 18, 2004 | 11:18 AM
  #145
PA TL's Avatar
Originally Posted by PA TL
Cruise control will not stay engage. Brake switch was replaced but problem persists. If control module were to be replaced, Module is CAD$500 or US$350.
Well, I finally locate my cruise control kick-out problem. It was in the cruise control module. The dealer said this is the first one that they have seen failed. It was CAD$460 plus labour to replace. Done almost a month ago.
However, just hit a deer last night so the insurance company may write the car off.
Old Nov 18, 2004 | 11:22 AM
  #146
PA TL's Avatar
If the tiny bulb burnt out in the high beam indicator in instrument cluster, that is a pretty easy fix.
However, the high beam bulb may be linked to this indicator on the instrument cluster.
I do not know.
Old Nov 30, 2004 | 03:07 PM
  #147
PA TL's Avatar
Signing off from the 1st Gen forum forever as the insurance company has written off my car (after collision with a deer).
Thank you for everyone's assistance.
However, I will see you in the 3rd Gen forum instead.
Old Nov 30, 2004 | 04:45 PM
  #148
Ken1997TL's Avatar
Enjoy the TL (reborn)
Old Dec 16, 2004 | 02:07 PM
  #149
AcuraDrivinJess's Avatar
My d4 light has never gone out lol, slow driver window and driver seat but thats it
Old Dec 19, 2004 | 04:26 PM
  #150
Lillybear's Avatar
How do i change my oxygen sensor? on 97 3.2 tl?
Old Dec 19, 2004 | 04:52 PM
  #151
Ken1997TL's Avatar
It is covered for FREE by your Acura dealer due to a federally mandated emissions warranty.
Old Dec 29, 2004 | 09:27 PM
  #152
delicate483's Avatar
was it shifting real hard from 1st to 2nd? and the tranny flush definately fixed it?? i just bought mine ('96 3.2) and have had all the same problems...
-starter (replaced the starter silanoid and fixed it)
-wind noise
-D4 lights out
-slow windows
-the latch on the cup holder cover broke
-hard shifting
also, should i be driving in D3 OR D4????
Old Feb 13, 2005 | 09:49 PM
  #153
zenyatta1's Avatar
97 TL 2.5
Slow front windows
Squeel from Driver's window when raised.
Starter replaced
CD Player not working
ECU replaced by Acura under special emissions waranty
I think that I'm going to be replacing the rear struts soon.
Starting to get wind noise from the front windows.
I get about 23-24 mileage with both high speed highway and regular road driving.
Old Feb 14, 2005 | 06:18 AM
  #154
UnsanePyro's Avatar
Registered Driver
-wind noise
-D4 lights out
-slow windows
-hard shifting
My tranny was shifting hard, a tranny flush at the dealer fixed it quite well (97 2.5). The D4 light is easy to fix, theres a how too on the site. The slow windows are a quick fix as well. My cupholder broke too, I think I'm getting a new one though . You should drive in D4 so it can get into the highest gear possible. D1 limits the car to 1st, D2 2nd, D3 3rd, and D4 final. You can use D3 in really hilly conditions though, and it will help keep you from having to ride the brakes, but almost always D4 is best.
Old Feb 22, 2005 | 09:36 PM
  #155
L8R-TL's Avatar
Trouble with AC Control Unit
My 97 3.2 has most of the same common problems. The newest one is my A/C Control Unit has gone out. A/C & Heat work great, but the display is gone! Dealer wants arm & leg to replace the entire unit! Found a couple locally, but not sure if they work. Anyone else with info on this? Greatly appreciated!
Old Feb 22, 2005 | 11:09 PM
  #156
Cornflake's Avatar
Reppin' the T-Dot!!
If they are local, just go there and take yours out and swap it there to test it, not a really difficult swap, that way you can find out before you buy!! If they won't let you, don't buy it!
Old Feb 23, 2005 | 12:53 AM
  #157
Ken1997TL's Avatar
Yeah, its an easy swap.
Old Mar 1, 2005 | 05:15 PM
  #158
bpjadhav's Avatar
1998 2.5TL
Bought my 98 2.5TL at 84,000miles (current mileage 98,500)
Problems:
1) D4 light out
2) An A/C relay went out...had it replaced.
3) Trunk leaks
4) Radiator Fan motor went bad....fan was vibrating real bad - got the motor replaced
5) Radiator was leaking from the top...wasn't bad enough to have it replaced...but did so coz the coolant was spraying around at high speeds (Got a pretty good deal from RadiatorBarn).
6) Heater blower/fan takes a few minutes to come on sometimes
7) The emergency brake light tends to stay on even if the brake is not engaged (This typically happens on really cold winter mornings...and goes away once the car warms up).
8) Suspect an exhaust leak...not sure on this (coz it's not loud...just a wee bit loud to get me suspicious)...just hoping it's not a cracked manifold.
9) Get about 21-22mpg (city/hwy)
Maintenance done so far:
Changed the Valve cover gasket, spark plugs, fuel filter, air filter. Had the Transmission fluid changed.
Will have my timing belt, water pump, tensioner and drive belts changed soon.
Does anyone know what is the recommended interval to change the fuel filter?
This is my first Acura...and it's converted me to the Acura camp! TL's are the way to go!
Thanks!!!
Old Mar 2, 2005 | 01:15 AM
  #159
Erik B's Avatar
3rd Gear
Exclamation
'96 2.5 tL prem
door lox freeze up
door lox operate independant of human touch(poltergeist?)
slo..oo.ow windows
squeaky windows
D4 light!
1st. to 2nd shift (i'm waiting...)
cd player skips when driving over large bugs in road
need to attend MIT to figure out heater/ac controls(ac, on, off full auto, half manual...wha the ...?)
Old Mar 2, 2005 | 01:33 AM
  #160
Erik B's Avatar
3rd Gear
Unhappy crankshaft pulley prob
has anyone had a problem with
the harmonic balancer(crankshaft pulley)
mine crapped out and started a screeching
sound and wobbled almost completely off,
taking all accessory belts with it.
watch for it, repair cost can climb into the
the stratosphere.
