checkin abs codes on a 2.5TL
Old Mar 9, 2010 | 03:31 PM
Alperovich's Avatar
6spder
any suggestions other then taking it someplace to check it?
Old Mar 9, 2010 | 03:56 PM
tempetom's Avatar
I think the procedure is the same for the 2.5 and the 3.2, but I'm not sure.
TexasHonda posted the procedure awhile back, but simply put, you look under the glove box near the floor and there's a mated blue 2 pin connector. Separate it and jumper the pins with a paper clip. When you turn the ignition to on, the ABS warning will flash the code. Going by memory, the first flash is a very long one followed by a number of long, but not as long flashes, then a pause then a series of short flashes. It will repeat or flash additional codes next. There's a section in the manual that tells what the codes mean and someone, even me, can tell you what they are.
Sorry to rely on memory only, but I'm up to my ears in starter problems and can't take too much time.
First I go back a page or two and look at ABS problems on this site.
Good luck
Old Mar 12, 2010 | 06:30 PM
TexasHonda's Avatar
Tempetom got it right. Post your code or PM your email address and I'll forward code sheet to you.
good luck
Old Mar 12, 2010 | 08:50 PM
Alperovich's Avatar
6spder
thanx for the quick reply. i ended up finding pdfs of the service manual after doing more digging. thanx for the input!
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
