Car won't start or shift from park
2007 6SMT Type-S
I had an aftermarket alarm installed and I thought that was the source but my installer removed it and still no luck
THE SYMPTOMS:
The engine will turn over, but just as it's about to start or run on it's own, it dies. My installer says that right at that point, power is "cut" from the igintion. I don't hear that normal electrical whine when you turn the key to the "on" position either. Lastly, I can't get the shifter to shift out of park. WTF?
THE SYMPTOMS:
2007 6SMT Type-S
update
So my windows won't roll down either. I used my key to "unlock" the gear selector, put it in neutral, and tried to start it but same problem exists.
大日本帝国
THE SYMPTOMS:
THE SYMPTOMS:
~Cheers~
大日本帝国
If those aren't, then the keyswitch is jumping from I (Acc) to III (Start), and not staying on II (On), which is where it needs to be for the main relay to turn on the fuel pump and power the windows.
~Cheers~
2007 6SMT Type-S
Your windows won't roll down even in II? Are the dash lights coming on, i.e., ABS, CEL, etc.?
~Cheers~
~Cheers~
Now the question is: what do I need to fix? The whole ignition switch? I wonder if the guys that stole my car jacked it up?
You only need to replace the keyswitch assy. It's held in place by two smooth, rounded security bolts. You remove the shroud, and back the bolts out by punching edge of bolt w/ cold chisel or hardened punch. They are not tight usually and easy to start turning. Once loose you can back out w/ your fingers. Unplug old switch assy and remove, reinstall new.
good luck
good luck
'13 Hyundai Sonata
2007 6SMT Type-S
good luck
good luck
大日本帝国
Man I love this website! Once again, thanks for coming through for me, Go90. After you mentioned the dash lights I coudn't remember if they came on or not so I tried and sure enough...no dash lights. So I pressed the windows while I turned the key and they moved for a split second. So I finagled the key and was able to get the key to "stick" in the "II" position and everything worked like normal!
However, I don't think the thieves damaged it that way. They might've damaged the cylinder, but not the switch since it's a normal wear item ESPECIALLY for mid-90's Hondas.
~Cheers~
2007 6SMT Type-S
I didn't know that it was a common problem, but I do know. I'm going to order a new ignition assy on Monday. It sounds like it's a pretty easy fix, so I hope to have it fixed tomorrow if they have one in stock.
good luck
^ my ignition switch got real bad it wouldnt even let me pull my key out! i fixed it with some electrical cleaner, sprayed it into the keyhole and flushed all the shit out. now it works like new
good luck
be sure to check your fuses under the kick panel driver side. my car would not start nor shift out of gear. come to find out. it was my E.A.T.ECU fuse/etc... i believe it was a 15 fuse .. i replaced it and it shifted and started right up.
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
