Brake Booster Vacuum Leak?
Old Dec 5, 2012 | 08:12 PM
main70072's Avatar
I changed my front calipers last weekend, bleed the lines, and noticed a hissing sound coming from the master cylinder area shortly thereafter. I finally had the time to look at it more closely today since I didn't saw any fluid leak or loss of braking ability at the time. After feeling around the area to find where the air leak was coming from, I found that the hissing sound was coming from in between the master cylinder and brake booster. The hissin sound would go away a few seconds after turning off the engine. What can be the cause of this problem?
Old Dec 10, 2012 | 09:16 AM
main70072's Avatar
No one ever had this problem before? I'm thinking there may be a seal between the master cylinder and booster...
Old Dec 10, 2012 | 09:21 AM
your assumption might prove to be correct.
there are lots of seals in the brake booster.
if one goes bad, you could be searching for a leak/air in the lines for days
Old Jan 14, 2013 | 05:28 PM
96acura3.2tl's Avatar
I also had a problem with my brake booster, I got a used one from car-part.com.
https://acurazine.com/forums/1g-tl-problems-fixes-118/brake-booster-help-786282/
Old Jan 14, 2013 | 06:20 PM
main70072's Avatar
Mines still work normally, just loose the ability to brake once car engine is off.
Old Jan 14, 2013 | 07:03 PM
When I had this same problem the car will still brake but the pedal will go all the way down to the floor and also won't stop like right away.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
steve
Sep 30, 2015 09:23 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
