Alternator Failure w/o Charging Light
Old Jul 15, 2007 | 10:27 AM
TexasHonda's Avatar
My 97 Acura 2.5TL has an alternator w/ no output and the charging light does not come on when engine is running. It is on w/ keyswitch in ON position, but goes off when engine is started. Only way to keep car going is to charge the battery.
Looking at the Acura shop manual wiring diagram the charging light ground simply goes to the voltage regulator, and there is no detail of internal circuitry of voltage regulator. I assume this means the voltage regulator has failed, but was interested whether others might have encountered this problem.
Regards
Old Jul 15, 2007 | 08:05 PM
tlmadness's Avatar
did you put in one of those house shaking sound systems?
Old Jul 16, 2007 | 06:02 AM
TexasHonda's Avatar
No, it is completely stock.
regards
Old Jul 16, 2007 | 12:50 PM
tlmadness's Avatar
you can tell if its the alternator if the likes dim when you race the car.
Old Jul 16, 2007 | 06:58 PM
TexasHonda's Avatar
I have a voltage monitor and it's not putting out any voltage. Battery gradually discharges till no-start. I have a used part on order and will rebuild my own alternator.
thanks
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
chrisr
Dec 4, 2015 02:17 AM
Phambam12
Sep 6, 2015 06:57 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
