ABS Light ON
Old Jul 7, 2008 | 12:39 PM
Baker831's Avatar
ABS Light ON
My ABS light just recently turned on. Ive been looking around online trying to find a fix for this, and I see people asking for codes and what not. How do I figure this out? How do I check the codes, or find out what I have?
Old Jul 7, 2008 | 07:20 PM
01tl4tl's Avatar
is the brake fluid level full, and the slider inside its cap is working?
Have any major parts store come outside to the car - they plug in a scanner and get whatever codes are there
Could be a speed sensor or dirty fluid in the system
Whens the last time you flushed/bled the brake fluid fully?
Needs to be done every year to prevent internal mositure buildup in the system-
google hygroscopic for more details
Old Jul 8, 2008 | 12:09 PM
TexasHonda's Avatar
ABS code can be extracted by shorting the service check connector under the glove box, a blue 2-wire female connector plugged into a dummy male end. Short the connector, turn keyswitch to ON, and ABS light will flash codes w/ one iniital long flash (system working), followed by codes in short flashes (f) w/ short pause (p) between 1st and 2nd digit of code. For example ffff-p-f = Code 4-1.
Download the TL manual for details of codes or post your results, and I'll try to help.
good luck
Old Jul 8, 2008 | 06:01 PM
DAiNiUS's Avatar
Off Topic - your car looks real nice in the avatar, mind posting up some pics so we could have a better look at it
Old Jul 11, 2008 | 04:41 AM
Baker831's Avatar
Thanks for the tips. Im going to give them a try and ill get back to you guys on that.
BTW thanks for the comment on my avatar. For sure ill put up some more pics of my TL.
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
