2.5TL 96 won't start
Old Dec 7, 2015 | 10:47 PM
Mugenx's Avatar
Hello to everyone:
I just changed my starter, alternator, spark plugs, battery, battery cables, fuses
but yet again my car isn't starting it would crank/turn over it would start for like 2mins but its like having hard time getting energy. I run OBDII scanner but no codes reads, so now I'm stuck /i don't know what else or step I need to do. one of the video I have watch a guy changed his alternator and He said "don't forget to jump your car so it would generate power to the alternator" so now im eager to buy a portable jump start device I will also take a video of my car while starting. TYVM any help/suggestion is greatly appreciated.
Old Dec 8, 2015 | 12:42 AM
01acls's Avatar
How about fuel? Is the fuel pump working? Crank the car for a little while but don't over do it or you can damage the starter. Then inspect the spark plugs and see if its wet.
Old Dec 8, 2015 | 02:54 PM
Mugenx's Avatar
I start the engine it cranks and turn over but only for less than a minute then died and check spark plugs its wet and smell a little of gas is that normal? il post the video later when i get home
Old Dec 8, 2015 | 02:57 PM
01acls's Avatar
Yes normal.
Old Dec 9, 2015 | 12:48 PM
Mugenx's Avatar
Here is the link for my video when I try to start my car :
Old Dec 9, 2015 | 12:55 PM
Mugenx's Avatar
I changed a lot of parts of these car: when i first bought this car to a "friend" said no problems at all no mechanical nor electrical bought it for $2100 then i have it inspection took it to japanese import mechanic said broken axle Rt/Lt, new booth struts/shocks brakepads/rotors replaced it all cost about $1400 +labor about $900 and now just spend another $450$ this is giving me nightmares. all i want is for these to run properly and well taking care off. febuary im replacing it maybe toyota tacoma or ford ranger but i still want this so run properly.
Old Dec 9, 2015 | 02:22 PM
01acls's Avatar
You're not cranking it long enough and it sounds like sometimes the starter is not engaging? Kinda hard to tell from video.
Did you try holding the butterfly open when starting to see if it will start?
You need to start with the basics... air fuel ignition.
Check the idle screw in TB?
Your tl is notorious for clog egr/clog plentium?
Old Dec 9, 2015 | 07:59 PM
Mugenx's Avatar
I forgotten to mention that the car has ignition bypass. I press a button to start the car after i turn the key to engine on. I'm not familiar about the butterfly and where it would be located and what idle screw on throtle body?
Old Dec 9, 2015 | 09:04 PM
01acls's Avatar
Hold the gas pedal down that will open the butterfly.
X is where the idle screw is (behind the hose).
Ahh, you need to buy a service manual.
Old Dec 10, 2015 | 02:49 AM
Mugenx's Avatar
oh I have service/repair manual but the book doesn't cover as much compare later model and by the way I would like to thank you for responding and helping me out I am grateful and really appreciated all the help. by the way my TB cable seemed to be loose even i slightly hold it the cable goes out of track.
Old Dec 10, 2015 | 02:57 AM
01acls's Avatar
The cable is not suppose to be tight nor taught but not loose either. Should be on the soft but not loose side.
If its too tight the throttle may get stuck on/butterfly open. Which is dangerous. So better to error on loose side.
The manual should have directions on the proper tension adjustment.
D4nnyD
2G TSX Problems & Fixes
Feb 11, 2016 09:04 PM
CAB NY
Dec 22, 2015 03:39 PM
GraveDigger
Dec 8, 2015 01:42 AM
xBlue
Southeast
Dec 7, 2015 05:08 PM
