1997 3.2TL ABS light code help, please?
Old 08-17-2011, 09:29 AM
3.2TLGirl's Avatar
I shorted the connector under the glove box as TexasHonda writes and here is the result. If someone could interpret what these flashes mean, that would be great. If TexasHonda could reply, that would be even better.
Thx.
1 Slow
7 Fast
5 sec. pause
8 Slow
1 Fast
5 sec. pause
Repeats
Old 08-23-2011, 08:21 PM
TexasHonda's Avatar
Code 17 = LR Wheel sensor open/short to ground or short to power.
Code 81 = CPU. It could be a CPU fault or perhaps just needs to be reset.
Suggest fixing the wheel sensor (check resistance perhaps 550-850 ohms from 97 2.5TL manual). Replace if defective. Check ebay, amazon, car-part.com for used parts.
If you need a replacement CPU, check ebay or car-part.com for parts.
good luck
Old 08-25-2011, 06:40 PM
3.2TLGirl's Avatar
Thanks a bunch, TexasHonda, for your reply and the information. I'll take a look at the wheel sensor after the hurricane passes.
mada51589
05-03-2022 08:54 PM
Big mo
4G TL Problems & Fixes
09-12-2015 07:22 AM
Bahamanurse1
09-10-2015 10:05 PM
HeloDown
09-08-2015 06:51 PM
Stu2414
08-30-2015 07:30 PM
Quick Reply: 1997 3.2TL ABS light code help, please?
