Some teasers for now :)
I knew the headlights would get a reaction out of you.
I'm going to install them as soon as I get my HIDs in.
I'm going to get a price on the bumper repair some time next week. Hopefully it isn't too much.
Just getting the wheels has really changed my mind on so many things.
You don't have to go through all this if you don't want to. It is very little diff.
So Mike, how do you like the fact that the bulb is a little crooked compared to the USDM? I mean that the headlight bulb goes in at an angle vs. having the top tab straight? Is it messing your beam up? I had corrected it by rotating the D2R do that the ceramic was still at 90*, but that's because that Casper didn't have an alignment pin.
~Cheers~
~Cheers~
You think that if I swapped out the holder from the USDM light to the JDM light that I would be good?
Also.....
I have a valve issue right now that is going to drive me up a damn wall.
Also.....
No, it's the reflector housing itself. You'd have to remove the reflector assembly from inside the headlight and swap it over. At that point, you might as well just switch the frame over.
I not that great with a heat gun, and messed up one of my headlights since unlike Civics, we have hella glue holding everything together. It takes so long to heat I accidentally deformed some of the black side. Oven FTW.
~Cheers~
~Cheers~
Damn Mike. You are doing it big. Hope to see some more pics soon.
