AiR INTAKE
Old Jan 25, 2011 | 02:07 AM
J.L0U Da Pr0Duc3R's Avatar
Lightbulb AiR INTAKE
Ok. i have a "96 Acura TL (2.5) So im stuck b/t intakes.
AEM Dry Flow Filter VS Weapon-R Dragon Intake
which 1 shall go in my car. Your opinions are heavily considered & respected.
Thank You Acurazine (1st gen TL)
Old Jan 25, 2011 | 09:47 AM
main70072's Avatar
Some members on here have bought and recommended the Secret Weapon Intake. Not sure about the AEM Dry Flow Filters.
Old Jan 25, 2011 | 03:05 PM
bigwerm187's Avatar
Str8 Home built
the weapon r is only for the 3.2 for the 2.5 i made mine lol
Old Jan 25, 2011 | 04:31 PM
pro_found973.2TL's Avatar
they do have WR's for the 2.5 but i would just make my own like bigwerm said. ive heard that the aem dry flows r very good quality and easier to clean vs the k&n(hence "dry flow"). personally i pieced together my SRI on my 3.2 TL. i switched it over from my legend when i totaled it. but originally i just bought crappy intake off ebay for like $20, shit canned the filter it comes with and bought a 3' inverted k&n filter for about $50-$60. less than $100 and got a good quality SRI. the weapon r just looks cooler tho. good luck
Old Jan 25, 2011 | 07:11 PM
Go90go's Avatar
大日本帝国
Dragon filters suck. A crappy pipe with a good K&N or even the AEM Dry Flow would be good. The difference between the Dry Flow and the old AEM and K&N filters is that the Dry Flow doesn't need to be oiled, which can be a pain to do. You have to spray lightly then let it dry before you can put it back on the car.
~Cheers~
Old Jan 26, 2011 | 12:40 AM
true...those sponge-like filters r garbage! i would go with the dry-flow...good filtering and easy maintenance
Old Mar 30, 2011 | 03:08 AM
XAviatorX's Avatar
7th Gear
is it bad just to install an air intake and not to have an exhaust system? isn't it bad for the engine because its taking way more air and the exhaust is smaller then the intake
Old Mar 7, 2012 | 11:50 AM
Chee2o's Avatar
I've used and would avoid the K&N unless you're a pro at cleaning and re-charging often with the various weather, seasons and conditions. Not only do you need enough oil on the filter which most people under oil- they work better the wetter and dirtier. The caveat is if you over oil, it will be pulled into the system, build up and cause issues.
I've been reading up on it for my 3.2 and am not sold on the Dragon, AEM appears to be decent but the proper way to go although more costly is Injen. They lab test, Dyno and back-up claims with data. It's the best engineered dry filter cold air intake set-up available. Happy searching!
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
