you know what would b nice ??
Old 06-16-2005, 10:04 PM
TLO03's Avatar
a remote trunk button... while the dealer was f'in around with my tl they gave me a 05 sentra rental it had a remote trunk opener, seems like every time i got to get in the trunk i miss that sentra's button ( just the button that's it). can i make this mod happen??
Old 06-17-2005, 12:18 AM
demons rage's Avatar
yea you can... i know my karr alarm system that came with the car has the remote trunk option... the car just doesnt have the parts installed to make it happen... xP
but getting back to your original question, this mod can happen with the right... tools/parts/whatever the heck is needed... woudl give you more info but heck i dont know much about it...
Old 06-17-2005, 03:32 AM
Ken1997TL's Avatar
Received 2,329 Likes on 1,309 Posts
You need a solenoid to unlock the trunk latch and of course the wiring and remote. Its possible but you need to do your homework on this.
Old 06-17-2005, 02:21 PM
OMG! Oh N0ES!
cambo's Avatar
The reason why this is so difficult for our TLs is it uses a wire latch system. Its easiest on cars that use a button to open the trunk. However, i'd like to look at my brother's 2001 Accord because his car uses a wire-latch system and his car has a factory trunk opener on his key fob.
Old 06-17-2005, 03:51 PM
LDH
I
LDH's Avatar
you need a trunk actuator to unlock it and a solenoid to make it pop up. A trunk actuator is electronically controlled, of course you'll need an alarm system that will support the actuator. I think DEI makes a system that works with oem actuators.
Old 06-17-2005, 04:59 PM
Hurricane Game
dubcnea's Avatar
"man i dunno....that....sounds like a lot of work."
Old 06-18-2005, 12:46 PM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
naw i bought one for 30 bucks and installed it in about an hour... really quick
Old 06-18-2005, 03:17 PM
Reppin' the T-Dot!!
Cornflake's Avatar
Yeah, it's not that bad. Just need the solenoid and an alarm with e trunk output. That's all.
Old 06-18-2005, 06:14 PM
OMG! Oh N0ES!
cambo's Avatar
from?
Old 06-19-2005, 09:15 AM
KaMLuNg's Avatar
look around ebay for a trunk solenoid or trunk actuator... if ur alarm has a aux button wire it to that... u will most likely need a relay also... if u do not know how to install it.. have someone do it.. not worth burning out ur alarm or anything else...
Old 06-19-2005, 09:18 AM
KaMLuNg's Avatar
oh yeah one think to keep in mind when u are installing the solenoid.. our trunk have a supersmall sensor that detects if ur trunk is open.. this is the light in ur dash that comes on... with the solenoid in place..u may have to bend the trigger a little so it reaches the button when the trunk sits closed.. otherwise that light won't ever turn off and 9 times out of 10 u will have false alarms or ur trunk won't even arm.
Old 06-19-2005, 06:00 PM
TL-Ridaz96's Avatar
One question...How do you remove the cable from your trunk? I want to manually open the trunk with the key and not the trunk release handle by the driver seat.
Old 06-19-2005, 06:47 PM
TLO03's Avatar
i don't about the tl's, but in previous vehicle's it was just a cable like old school bike brakes. braided steel cable w/a round metal ball or cylinder.
Old 06-19-2005, 10:00 PM
Ken1997TL's Avatar
Thats how it is in the 1st gen TL's.
Old 06-20-2005, 07:45 AM
Reppin' the T-Dot!!
Cornflake's Avatar
Don't you have the key lock on the trunk release? Just lock that and the only way to pop the trunk will be with the key in the trunk only. This is there so that when you take your car in for service you can give them the VALET key which only opens the doors and ignition, won't open the trunk or unlock that release or glovebox.
MrHeeltoe
20
02-23-2023 01:54 PM
hashbrown
02-18-2022 11:20 AM
MrHeeltoe
09-29-2015 10:43 PM
hashbrown
09-29-2015 12:13 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: you know what would b nice ??
