you know what would b nice ??
a remote trunk button... while the dealer was f'in around with my tl they gave me a 05 sentra rental it had a remote trunk opener, seems like every time i got to get in the trunk i miss that sentra's button ( just the button that's it). can i make this mod happen??
yea you can... i know my karr alarm system that came with the car has the remote trunk option... the car just doesnt have the parts installed to make it happen... xP
but getting back to your original question, this mod can happen with the right... tools/parts/whatever the heck is needed... woudl give you more info but heck i dont know much about it...
You need a solenoid to unlock the trunk latch and of course the wiring and remote. Its possible but you need to do your homework on this.
you need a trunk actuator to unlock it and a solenoid to make it pop up. A trunk actuator is electronically controlled, of course you'll need an alarm system that will support the actuator. I think DEI makes a system that works with oem actuators.
look around ebay for a trunk solenoid or trunk actuator... if ur alarm has a aux button wire it to that... u will most likely need a relay also... if u do not know how to install it.. have someone do it.. not worth burning out ur alarm or anything else...
oh yeah one think to keep in mind when u are installing the solenoid.. our trunk have a supersmall sensor that detects if ur trunk is open.. this is the light in ur dash that comes on... with the solenoid in place..u may have to bend the trigger a little so it reaches the button when the trunk sits closed.. otherwise that light won't ever turn off and 9 times out of 10 u will have false alarms or ur trunk won't even arm.
Originally Posted by TLO03
i don't about the tl's, but in previous vehicle's it was just a cable like old school bike brakes. braided steel cable w/a round metal ball or cylinder.
Originally Posted by TL-Ridaz96
One question...How do you remove the cable from your trunk? I want to manually open the trunk with the key and not the trunk release handle by the driver seat.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
