Wiper Blade Issue... Help please!
Hey guys, I searched the other threads but could not find a problem like the one I am having... So the other day it started to rain and I turned my wipers on... No problem, except for the fact that the high setting does not work!
Intermittent---Works
Low sett-------Works
High sett-------No Work
Wiper spray---Works
Also, you know how you can push down on the little lever, and the wipers will cycle once for quick wiping...yeah that does not work either...
I checked the only fuse I could find by the dead pedal... Also checked under the hood and could not find any other fuses... Anybody know what this could be?
Wiper spray---Works
if any other settings stop like intermittent for example then everything will slowly stop one after another. if this happens the problem is your wiper motor. u can get an aftermarket motor for around $80. u can install it your self or pay for labor. i found a place that installed my wiper motor for $85. thats the cheapest you'll ever hear for labor on that. most places charge $150 or more for labor on that. i doubt it's the switch which others might think its.....good luck
Thanks for the response tho!
same thing happened to me. in my case the slow speed stopped first. I used the fast speed for about a moth but then that went too. Next thing i knew the wiper wouldn't come on at any speed. I put in a new wiper motor and know everythings back to normal.
I agree with your theory but I think the entire motor will die eventually.
Maybee if you fix that one setting the motor will be saved but for some reason once one setting goes the rest follows.
Let me know what happens.
