what size bolts on rear caliper
1997 3.2TL
I am trying to change my rear rotors and pads on my 3.2 and i cant seem to find a socket that will fit its like its between a 11mm and 12mm the 12mm is to big and the 11 to small, what size is it suppose to be? This is kind of crazy
I suspect someone has rounded them off due to rust and/or wrong size socket. You may need a "rounded bolt socket" to remove (Sears has them). lso try a SAE socket to see if it fits.
I would get some new bolts from Acura or Honda. I thought they were 14mm socket size, but could be wrong. Check other side of car maybe they're undamaged? Manual doesn't say what the size is only the torque, 17 ft-lbs.
good luck
good luck
1997 3.2TL
I actually got them off tonight with an adjustable wrench, i will be replacing them with some new bolts from Honda, its strange though cuz they werent rounded off, btw these are the bolts that u remove to change the pads not the actual caliper bolts, the caliper bolts are definitley 14mm, appreciate the help texashonda, this forum is a lifesaver
cycdaniel
12-17-2019 10:58 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
