What the hell is going on?
2003 Acura MDX
Lately it seems like my car just has NO power what so ever....
what could be causing this and what shuold I do?
The obvious ones in order of most probable:
clogged air filter
very low tire pressure
clogged fuel filter
bad accelerator cable
There's plenty of others but that would assume larger malfunctions.
clogged air filter
clogged fuel filter
Received 2,329 Likes
Clean your EGR valve
2003 Acura MDX
Wackjum...
Yesterday when I was working on my left foglight, I took out alot of my air intake so I could work on the foglight better, so thats not it.
I when I have my oil changed, my mechanic checks my tire pressure and fills the tires if they need to be filled.
Ill have the fuel thing checked out, and Ill look at that cable..
My mechanic said I need a new pcv valve, an auto parts store is ordering it for me, but I dont think it should make THAT much of a difference, should it?
大日本帝国
Originally Posted by cambo
bad gas?
did you make sure that the gas you have doesn't have 10% ethanol addded?
~Cheers~
2003 Acura MDX
bad gas?
that type of gas makes a difference!? that could be it!!!
2003 Acura MDX
Originally Posted by KrayzieDxC
try puting the seafoam in your pcv valve or your break booster ..thas wat i did actually gave me some good acceleration
DIY?
08_UA7_Gr33k
02-11-2016 02:17 PM
DerrickW
11-15-2015 05:52 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
