VSS wire colors/signal
Hello all, so far I have managed to solve all my problems by searching but no luck on this one. I am trying to install my navigation system and I need to hook up to the VSS. What is the wire color at the ECU for the signal? Please help!
i think the easiest would be to tap the cruise control unit under the dash... see below for the wire...
1998 Acura TL Cruise Control Wiring Information
Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
- Constant 12V+ White Ignition Switch Harness or Use Hot Side of Brake
- Switched 12V+ Black/Yellow Ignition Switch Harness
- Ground Use Chassis Near Cruise Control Module
- Hot Side of Brake n/a Brake Switch
- Cold Side of Brake Green/White Brake Switch
- Tach Blue 2 Pin White Connector at Passenger's Strut Tower, 12 Pin PCM
- VSS Wire Orange Or Blue/White Pin 12 at CCM near Steering CO
- Pulses Per Mile 4000 PPM
Acura604
20
08-05-2017 12:55 AM
SUPRMN84
10-07-2015 09:46 PM
