Transmission
Transmission
My question is how strong or I should say , How many miles can the 96 2.5tl transmission handle ? The car is about to reach 160,000 miles.
I find the Shifting pattern wierd so to speak . If i am climbing a hill and the car is in overdrive , it shifts from overdrive down to second ( not into reg.drive) , when it does this it feels as it takes a while ( slipping feeling into gear) and u can feel a hard jerk(thud) when it catches second gear. I had my mechanic check it said it is normal . Is this true? All the mounts are good . Or am I just use to the shiffting pattern of a lexus ( I could never feel the transmission shift at all) . Thanks
Received 2,329 Likes
Partly age but partly by design.
Honda's automatic transmissions are unique in their construction. They dont use hydraulics nor planetary gears like 99% of automatics out there. Instead they are basically manual transmissions with a torque converter using stator force to change gears. Its a simple design, weighs less and is more efficient. The downside was a fairly crisp shift feel. Newer Honda automatics have improved software that smooths it out.
Try driving a late 80's Accord to feel a hard shifting automatic
大日本帝国
Try driving a late 80's Accord to feel a hard shifting automatic ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
~Cheers~
I had a new trans. filter and a complete trans. flush done . The old fluide did not look that bad at all and the screen had very little dirt or build up on it . I Cant Really notice a difference in the shiffting , so I assume it is suppose to shift that way. Thanks for the replys once again ;o)
joflewbyu2
10-08-2015 11:16 AM
