Tranny Problems ... 239k miles
Old 01-18-2010, 12:56 PM
Leuth's Avatar
Hi.
Before I did my tranny fluid drain/fill, my tranny was shifting hard. Now she's not wanting to shift out of first at all. I thought that this would go away, but it hasn't.
Is there a possible fix that doesn't involve a replacement/rebuild? Could I have done something wrong?
Old 01-18-2010, 02:15 PM
'13 Hyundai Sonata
TLin401's Avatar
Have you ever replaced the screen/filter?
Also did you ever change your differential fluid?
If those don't help then you are going to have to replace/rebuild the tranny.
Old 01-18-2010, 03:53 PM
Leuth's Avatar
Replaced the filter, put in Z1.
Did not change the differential fluid... would the differential cause it to slip? o _ O
Old 01-18-2010, 04:07 PM
大日本帝国
Go90go's Avatar
Make sure the filter is aligned properly. If it's a little off, it can cause it to hold a gear and/or leak. The diff wouldn't cause it to not shift, but changing the fluid would help performance and life anyway so you might as well do that. Fluid's cheap, too.
~Cheers~
Old 01-18-2010, 04:08 PM
tmnhs81's Avatar
^Ken had same problem.
Old 01-18-2010, 04:10 PM
Leuth's Avatar
!!!! Jesus Christwagons. So I might have done the job wrong. Gravy.
I'll drain it and take it apart again once I've got more create-a-seal and more tranny fluid.
Old 01-18-2010, 04:49 PM
tmnhs81's Avatar
You can reuse the one that is in transmission now. Assuming you recently put fresh fluid in.
Old 01-18-2010, 05:03 PM
Leuth's Avatar
Yeah, less than 5k miles on the current filter.
Old 01-18-2010, 06:15 PM
98 3.2 Flamenco Black
Mandy's Avatar
Sorry to hear...hope you get it resolved!
Old 01-19-2010, 01:23 AM
desired_speeds's Avatar
be careful to seat the filter correctly. My tranny was slipping because I used an aftermarket filter and it didn't fit 100%. I went back in and adjusted it and now it shifts smooth.
Old 01-19-2010, 07:37 AM
pimpin-tl's Avatar
You can reuse the same fluid you just put in. Just have a clean pan to drain into and put it back in.
Old 01-19-2010, 07:47 AM
The Box
vas25tl's Avatar
Let us know if it was the fitment of the filter.
Old 01-20-2010, 09:18 AM
Mandy's Avatar
True, as a precaution, use a clean cloth and filter the fluid and re-use it. Good luck and let us know.
Old 01-21-2010, 08:49 AM
Leuth's Avatar
As soon as I find the time and the place to do "the deed", I will let you know what's up. :3
Old 01-21-2010, 06:54 PM
aka romeo da kid
vipstar's Avatar
Location: i live north of knoxville, TN and south of Bristol, TN
oh man . i just picked up my tranny screen and gasket today and was gonna tackle that tomorrow. i hope mine doesn't do that shit. mine shifts fine, i just wanted to change it since i'm sure its never been replaced in its 14 year existence.
Old 01-21-2010, 08:32 PM
'13 Hyundai Sonata
TLin401's Avatar
IMO if it doesn't shift bad doesn't fix it.
Just wait until he doesn't shift right.
Old 01-21-2010, 08:49 PM
aka romeo da kid
vipstar's Avatar
huh?
i don't plan to keep the car that long. i'd rather do it now and that way then next owner can relax knowing he bought a bad ass ride.
Old 01-21-2010, 08:50 PM
'13 Hyundai Sonata
TLin401's Avatar
True.
Replace the differential fluid while you are at it.
Old 01-22-2010, 08:59 AM
Leuth's Avatar
What kind of differential fluid should I buy for this thing? I was thinking Lucas gear oil, but should I go with something else that's more recommended?
Old 01-22-2010, 09:14 AM
'13 Hyundai Sonata
TLin401's Avatar
Valvoline 80w-90
That is what I have used and also many others here on the forum.
Old 01-22-2010, 05:59 PM
Leuth's Avatar
I don't trust valvoline. :p Would Lucas Gear Oil 80w-90 be good? How about Mobil-1? I use Mobil-1 10w-40 synthetic in my engine with a quart of Lucas stabilizer.
Old 01-22-2010, 06:30 PM
aka romeo da kid
vipstar's Avatar
"i'm glad to report that VIPSTAR successfully changed the tranny screen and gasket and the car is shifting like a Smooth Criminal"
i was a little worried that something might turn out . it took me about 50 minutes to do the job. (ok ok. it took my friend about 50 minutes to do it) i wanted to do it but when i left walking to Autozone to pick up some brake cleaner and a scraper. he tackled it and had the whole thing off. all i did was scrape the old gasket off in some areas.
but that aside, my car shifts nice. the only thing i didn't do was change the diff fluid, and thats only bc the guys at autozone said that the tranny fluid was "da same thing for that car". i assume they know little if any about the car so i was hoping to see what other suggestions you guys give Leuth. then from there i can determine what i'll put in mine.
Old 01-22-2010, 07:22 PM
Leuth's Avatar
I may tackle the job this weekend.
Probably tomorrow afternoon. I figure I'm going to go ahead and just buy a new filter, because I have the strangest damned feeling that I'm missing a rubber fitting. I remember seeing it, but I don't exactly remember seeing it ON the damned thing before I put it in... I guess I'll find out when I take it apart. But a new filter is only like $25 so big whoop, right? I'm going to go ahead and do a new drain/fill again and not use the old stuff.
Old 01-22-2010, 07:43 PM
Leuth's Avatar
Also--How MUCH Differential fluid should I be getting?
Old 01-23-2010, 02:36 PM
Mandy's Avatar
Get the big one, it will last you years. The are not expensive.
Old 01-23-2010, 11:12 PM
'13 Hyundai Sonata
TLin401's Avatar
You need about 1.3 bottles...so 2.
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
DS2000TL
09-09-2015 09:26 PM
HeloDown
09-08-2015 06:51 PM
Zonian22
09-02-2015 08:19 AM
Quick Reply: Tranny Problems ... 239k miles
