View Poll Results: TL Keyless Entry Remote + PROGRAM
![](https://acurazine.com/forums/images/maestro/polls/bar6-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar6.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar6-r.gif)
![](https://acurazine.com/forums/clear.gif)
0%
![](https://acurazine.com/forums/images/maestro/polls/bar3-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar3.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar3-r.gif)
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
TL Keyless Entry Remote PROGRAMING ANY ONE KNOW PLZ HEILP ME 98TL
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
HI
I WANT TO KNOW HOW I CAN RE PROGRAM MY 98 TL Keyless Entry Remote
ANY ONE CAN HELP ME PLZZZ :yuck:
I moved this to 1G TL, where you will be more likely to get answers pertaining to your model year car.
Welcome to the forums, and I hope you can find out what you need to know, as well as more useful information.
INSTRUCTIONS
1998 2.5TL with factory-installed security
system
1996–98 3.2TL with factory-installed security
system
Programming the Transmitter
NOTES:
• This system accepts up to two transmitters.
• Entering the programming mode cancels all learned
transmitter codes, so none of the previously
programmed transmitters will work. You must
reprogram all the transmitters once you’re in the
programming mode.
1. Open the driver’s door.
2. Push up the driver’s door master power door lock to
the unlock position. Hold it there for the rest of this
procedure.
3. Insert the key in the ignition switch, then remove it.
Repeat this four more times within 10 seconds.
(Steps 3 and 4 must be completed within 10
seconds, or the system will exit the programming
mode.)
4. Insert the key in the ignition switch. Make sure the
power door locks cycle to indicate that the system
has entered programming mode.
5. Press the “LOCK” or “UNLOCK” button on the
transmitter. Make sure the power door locks (all
except the driver’s door) cycle to indicate that the
transmitter has been accepted.
6. To program a second transmitter, press its “LOCK”
or “UNLOCK” button within 10 seconds.
7. Release the master power door lock switch to exit
the programming mode.
system
system
NOTES:
programming mode.
procedure.
mode.)
Received 2,785 Likes
^^^ i think its cause hes a
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
![n00b](https://acurazine.com/forums/images/smilies/n00b.gif)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
