tire replacement and speedo issue
My 2.5TL with stock (15") wheels needed new tires. I had Goodyears but this time I got some rather reasonably priced Kumhos ECTSA HP4 stock size P205-60/R15. Turns out that after replacing tires the speedometer and odometer both indicate some problems. On a 600 mile journey the odometer now reads 614 positively I am going a bit slower than 70 mph when my speedometer reads 70mph because people kept passing me . Ofcourse this is not the correct speed test but wondering if anyone ever noticed such issues?
I am thinking that these new tires are probably about 3 or 5 mm smaller in diameter but can this happen for tires of same size as the previous set?
Received 2,329 Likes
Sometimes yes. Depends on your PSI as well.
TL no more!
I have the same problem too. I actually had to drive close to 75 mph in order to keep up with traffic. Also, when I tried to match my trip odometer with the mile posts on the highway, it reaches the mile about 0.07 miles too soon.
You could try tires that are 205/65 R15's
Thats what is on the 3.2's. Slightly larger overal diameter.
i THINK that usually with a smaller sidewall the car will take bumps much harder... it makes sense cause there is less cushion and bounce play... think about it when u have bigger rims and a smaller tire... when u hit that pothole it hurts... but my stock 15 will eat potholes all day...
Originally Posted by WolfpackBill
The problem with that is that mine IS a 3.2TL.
This is exactly why I posted this thread in the Tires forum. From that, you would easily be able to tell that the "60" in your tire size makes your RD smaller: that makes your speedo read faster and your odometer read high.
Reppin' the T-Dot!!
1 Post
Originally Posted by vishnus11
ken's right. i have 205/60 r15's and i get a bit of error especially on the hwy. BTW, do 205/60's ride slightly harsher than 65's because of the shorter sidewall, or is the difference unpercievable - the reason I ask is that I've never had my TL on 65's - the 60's it has now are the tire it came with when we bought it.
cammy5
09-04-2015 11:26 PM
asahrts
09-04-2015 05:55 PM
