Tccs
Originally Posted by binky
I'm sorry but what is TCCS? When i look for parts,it says with or w/o TCCS.I bet you I'll know if some one told me what it is in Japanese(lol).
So do mine
But only at 7000 rpms
Originally Posted by Ysidro
hey guys.
Im just curious.
Can the TCS be put onto a 2.5 model?
I mean for instance, Is it something we can buy from a junkyard and hook it up?
Im just curious.
Another dumb question ffom Japan...Is the TCS on a switch? I mean can it be turned on and off? Or is it a permanent system? And what is that "box" on the intake pipe,behind the radiator( the extra air-cleaner box looking thing between the intake pipe and the radiator)? Is it a necessity? Can it be removed...or not a good idea? First of all,WHAT IS IT?
Originally Posted by 03CoupeV6
Didn't you say your 97 3.2TL had VSA, as well? A retro?
Originally Posted by WolfpackBill
No...you're getting it mixed up. VSA is Vehicle Stability Assist. VSA helps control the car if it is oversteering or understeering, plus traction control to keep the front wheels from spinning. TCS is Traction Control System, which in the 1st gen TL's, restricts airflow to the engine to keep the front wheels from spinning.
Believe me, I know exactly what VSA and TCS are. I know my Acura, and my Accord, inside and out - backwards and forwards. The question was directed at Ken because I believe he told me that he retrofitted VSA from an RL onto his 97 TL and that it was a lot of work. You'd have to add yaw and steering angle sensors and a lot of extra equipment to piggyback the ABS sensors, which are also TCS sensors.
Took it from a late model 1st generation RL
Basically i retrofitted a 4 channel ABS system and the VSA "box" which is behind the rear seat.
Originally Posted by TLO03
what is the diffrenance on or off.???
Off = If you know what you're doing and dont want any electronic nannying.
Its personal preference really. The TCS is quite tame compared to most others, especially Mercedes.
How hard is a VSA retrofit?
At the time, I had a hookup thanks to a friend who was a Honda technician and a wrecked RL that was awaiting my experiments.
Basically the ABS system had to be completely removed and replaced, wheel sensors added in the rear (independent rather than the stock system that uses one channel for both wheels)
VSA's control box had to added and wired... I stayed away from doing the work myself, totally out of my field.
It works quite well and I'm wondering if anyone else out there has retrofitted such a system.
I did it for a technical challenge (and my friend needed the money due to family issues).
The TCS can be disabled, there is a switch for it next to the mirror controls on the left to the steering wheel.
If you have no TCS switch, you have no TCS. I'm also assuming you don't have a "TCS" light in the dash.
The switch is located beside your main cruise control button. If the button there say TCS, then you have traction control. Plus, you'll have a fog light switch beside your gear shifter along with the seat heater switches. If you don't have TCS, then the button beside your main cruise control switch is the fog light switch while depending on which model year, you'll probably have seat heater switches or nothing at all, not even dummy switches, beside the gear shifter.
Cost me $1,000 for everything.. and it would probably cost double that unless you have connections.
Originally Posted by vishnus11
any more info on this would be awesome ken. Looking to do the retrofit on my 3.2. Labor is cheap for me since my best friends dad is a honda tech. Parts are probably what a difficult to get. A four channel abs modulator, rear sensor, hydraulic wiring, and a vsa box? anything else? and how hard is it to wire the vsa box into the vehicle - for example what does it connect to?
The wiring was a pain from my understanding, it was put in the trunk right up against the seat (next to the ski pass through). I believe it connects to the ABS controller and possibly the engine management (the control boxes are in the front by the passenger's feet.
maharajamd
203
Nov 16, 2018 01:05 AM
gangstaTL03
Aug 26, 2008 09:26 PM
need4spd
Jan 9, 2004 02:43 AM
