Starter contacts for 3.2?
Is the starter a sealed unit as to where we cannot put new contacts in ourselves?
If so,which contacts would I need?(part number?)I do not have my starter out yet.
I have seen the website that texashonda put up a link to follow but I need to know which ones I need,...If they can even be replaced??
I found they were sealed on my 2.5TL.
I looked at 98 3.2TL starter and found the part image suggests the contacts are replaceable. I can't be sure but this looks like solenoid I replaced contacts on Accords and 2.2CL. The contacts go under the 3-bolt cover at upper end of drawing.
98 Acura 3.2TL Starter
good luck
good luck
check car-part.com for used starters for your car. They will provide all cross-over donors in their large inventory, so you'll know if later or earlier models are matches.
good luck
good luck
Pham Alvan
03-16-2016 09:17 AM
