Shift lock...
Old Aug 31, 2005 | 01:26 AM
Mikes96TL03CLS's Avatar
Shift lock...
I know my Accord had one, and I knew how to use it. So in our TL's, how does it exactly work?
Old Aug 31, 2005 | 01:44 AM
NFLblitze1's Avatar
Youse Gots Sacked
by the shiftplate, i don't know if this is for the 2g but its for the 3g TL's. you flip off that little plastic piece with a butter knife, and put the key in.
Old Aug 31, 2005 | 06:52 AM
spooky3ce's Avatar
Swift 3 B-A-N-G-E-R
Our TL's have a visable key hole next to the shifer... Stick your key in down until it pushes the little lever at the bottom... you can use something flat too as long as it pushes down the lever inside... while pushed down you can move the shifter into any gear...
Say your car doesn't turn on and you want to move it into the garage... Put your key in there... pop it in neutral... and PUSH the car in... I think you might need the key in the ignition too to unlock the steering wheel after you put the shifter in neutral...
Another example is if the shifter is in your way when installing your Aftermarket Receiver and or you are cleaning under the center console...
Old Aug 31, 2005 | 09:03 AM
WolfpackBill's Avatar
TL no more!
That's one part of the shift lock. Another part is your brake sensor. You know when you try to shift out of park in your Accord, you have to push the brakes then push the tranny button to shift out of park, right? Well, our TL's are a little different since we're using a gated shifter. In our TL's, when you hold the brake down, you can hear a little click at the tranny. That releases the lock. Then all you have to do is to pull the shifter out of park.
Old Aug 31, 2005 | 01:21 PM
Mizouse's Avatar
when i read the thread title i thought you were talking about drifting
Old Aug 31, 2005 | 01:54 PM
Haha. So is this in anyway a good theft prevention? So if someone hot wired my car, could they shift it or would they need the key?
Old Sep 1, 2005 | 01:35 AM
spooky3ce's Avatar
Swift 3 B-A-N-G-E-R
They could still take it... like wolfpackbill said... all they'd have to do is have the car on and push the break down... unless you rigged the sensor bill was talking about so you had to have the key... wouldn't know how to do that... kind of like a kill switch... flip it and the sensor can sense the break... flip it so it does't...
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
Popee
Dec 20, 2015 12:08 AM
mellsonnj
Sep 24, 2015 04:42 PM
Hines57
Sep 24, 2015 01:58 PM
