shift knob options/mod?
Old Jan 7, 2010 | 12:12 AM
pro_found973.2TL's Avatar
Arrow shift knob options/mod?
What woodgrain shift knobs from other acura models fit our 1st gen TL's? I've seen a few with the burl shift knobs with the acura "A" symbol on them but It never stated what model they got it from? If this can b done is it simple plug and play kinda thing or is there some modding that goes with it to make it fit?
Old Jan 7, 2010 | 12:32 AM
tmnhs81's Avatar
I think 1G MDX is the one people use most..
Old Jan 7, 2010 | 12:44 AM
Go90go's Avatar
大日本帝国
Almost any screw on manual shiftknob will work.
~Cheers~
Old Jan 7, 2010 | 12:47 AM
Ken1997TL's Avatar
RL knobs, especially '04 if you can find one at a good price
Old Jan 7, 2010 | 01:00 AM
Sweet! Ima look into the mdx and rl knobs. Thanks..
Old Jan 7, 2010 | 06:27 PM
NoShine's Avatar
Im rockin a tan leather stitched Legend knob. Matches my interior very nicely
Old Jan 9, 2010 | 11:57 PM
TLin401's Avatar
'13 Hyundai Sonata
I have been trying to find an RL knob in a salvage yard for a while now but no luck.
Old Jan 11, 2010 | 10:48 AM
Mandy's Avatar
98 3.2 Flamenco Black
That's what I have. Love it!
Old Sep 11, 2010 | 12:05 PM
calmoc9's Avatar
6th Gear
Is it the same size and thread pitch as older honda shift knobs?
Old Sep 11, 2010 | 03:45 PM
9632tl's Avatar
Radical Member
I just bought one on eBay
Old Sep 12, 2010 | 08:52 PM
Mandy's Avatar
Post a pic man!
Old Sep 13, 2010 | 12:37 AM
9632tl's Avatar
Radical Member
I will, once its delivered. If I can find the pic from ebay, I'll post it
Old Sep 13, 2010 | 07:22 AM
TLin401's Avatar
'13 Hyundai Sonata
How much did you end up paying for it?
Old Sep 18, 2010 | 09:51 AM
9632tl's Avatar
Radical Member
$35 I think. Someone was bidding against me for it
Old Sep 18, 2010 | 09:30 PM
9632tl's Avatar
Radical Member
Got it in the mail today. It doesn't fit :'(
The hole is too small for my shaft....first time THAT'S ever happened! Lol
I guess I will have to customize.
Old Sep 18, 2010 | 09:32 PM
9632tl's Avatar
Radical Member
Old Sep 18, 2010 | 09:33 PM
9632tl's Avatar
Radical Member
Sorry for double-post
Old Sep 19, 2010 | 04:39 PM
9632tl's Avatar
Radical Member
I had to *carefully* drill and re-thread the new knob, but its on now. It's made of real wood, even!
[IMG]http://i894.photobucket.com/albums/a...l/IMAG0003.jpg[IMG]
Old Oct 6, 2010 | 05:58 PM
K.Lindsay's Avatar
how did you drill and re thread finally got time to mess with it.. i got the 04 mdx knob..
Old Oct 7, 2010 | 09:08 AM
9632tl's Avatar
Radical Member
There is a small Phillips head screw inside the threaded hole, remove it.
I found a drill bit that was just barely bigger than the original hole. The bit should self-center its self, but be very careful. I had to drill down until I started getting wood shavings with the plastic.
Next, you need a 10x1.5mm tap. Again, it should self-center, but be very careful. If it is too hard to thread, go down the hole with a slightly larger drill bit. Don't go to large, or the threads you'll be making won't have any strength.
I used a few drops of atf as lube for the tap.
I did all this while holding the knob in one hand. If you use a vise, be sure to use a towel, so the knob isn't scarred.
SidhuSaaB
May 30, 2020 12:40 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Popee
Dec 20, 2015 12:08 AM
mellsonnj
Sep 24, 2015 04:42 PM
Hines57
Sep 24, 2015 01:58 PM
