Security/remote start installation.
Hi,
I finally decided its time to upgrade my factory alarm.
I went with a DEI 560XV that I'd online after doing some price comparisons.
Bestbuy had it for almost $300 bucks.
It has security+remote starting feature. So far I've installed it with no problem.
Everything works great.
Now Im trying to hook up progressive door luck.
For those that dont know what it is, it goes like this.
Press the unlock button once, it unlocks the driver door only.
Press it one more time, it unlocks all doors.
The problem I have is finding the Unlock motor wire/color.
I followed Directed vehicle diagram and cant seem to find it.
My question is, does anyone know where and how to find the Unlock motor wire?
Thanks.
Thanks.
HI,
Its a 97 2.5
I used the Directwire vehicle diagram to try and locate the Unlock Motor wire.
The diagram stated the unlock motor wire is red and the Lock motor is White/red.
By the way, does anyone know how to check the polarity of a wire with the digital meter? Someone told me once but I forgot. Once I get this done, I think I'm going to make a walk through DIY with pictures of where the wires are to install Security/Remote starter. So anyone else ever install the progressive door lock feature or know where the Unlock Motor wire is? Thanks in advance.
---------------96-98 Acura TL 2.5 Security/Remote Starter Wire diagram ------------
12volts=white (+ ignition harness )
Starter = black/white (+ ignition harness)
Ignition = black/yellow (+ ignition harness)
Power Lock= gray ( - passenger door harness)
Power Unlock =green/yellow (- passenger door harness)
Lock Motor =white/red ( driver kick panel)
Unlock Motor =red (driver kick panel )
Parking Lights = red/black (+ f-box, dr. kick, or dimmer )
Parking Lights= red/white (- security control module)
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger =black/white ( - plug at inst. cluster)
Dome Supervision
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Horn Trigger =blue/red ( - security control module)
Memory Seat 1
Memory Seat 2
Memory Seat 3
Its a 97 2.5
usually it is a wire that comes off a harness above the fuse box
Hazards
Turn Signal(L)
Turn Signal(R)
Dome Supervision
Trunk/Hatch Release
Power Sliding Door
Disarm No Unlock
Memory Seat 1
Memory Seat 2
Memory Seat 3
cak165
1G TSX Problems & Fixes
09-16-2015 08:17 PM
