Running Cold
Old Mar 13, 2009 | 09:11 PM
HighMileage2.5's Avatar
Running Cold
Lately, my 2.5 has been running very cold during highway trips. The temperature gauge shows a normal 1/3 or so deflection during city driving, but when on the highway with a constant speed, the temp gauge is down to the second hash mark. I travel in Oklahoma/Texas so the cold weather shouldn't prevent it from properly heating up right? Thought maybe spark plugs aren't igniting mixture 100%, but does anyone know what it could be or what it could cause?
Old Mar 13, 2009 | 10:06 PM
desired_speeds's Avatar
change your thermostat... which should be changed with coolant.
Old Mar 14, 2009 | 12:11 AM
Dozer's Avatar
Same here. I don't think it's a problem. It heats right up when I exit the highway and do some city driving.
Old Mar 14, 2009 | 01:08 AM
both of you replace your thermostats. Its not normal. the temp gauge is not supposed to fluctuate much after it has reached normal operating temp. Should take no more than 5-10 mins of driving to reach normal operating temp.
Old Mar 14, 2009 | 06:16 PM
Wish I Had A TL's Avatar
Cool
X2 You are also hurting gas mileage.
Old Mar 15, 2009 | 02:36 PM
Mr_Outside's Avatar
Is the normal place for the needle to be in the middle? Because my temp gauge has been doing the exact same thing since I bought the car.
Old Mar 15, 2009 | 02:53 PM
Ken1997TL's Avatar
It should be just below the middle or so.
Old Mar 15, 2009 | 03:44 PM
Mr_Outside's Avatar
How long should it normally take to get there? Mine takes like 15 minutes...
Old Mar 15, 2009 | 06:06 PM
TexasHonda's Avatar
A good OEM thermostat should reach operating temp in < 5 minutes of driving at 40-60 mph. You should notice the temp needle begin to rise quickly in 2-3 mins in moderate outside temps(50-70 F).
good luck
Old Mar 15, 2009 | 06:18 PM
Ken1997TL's Avatar
2 to 3 minutes of moderate driving and the heater has already kicked in full force.
Old Mar 15, 2009 | 09:35 PM
Dozer's Avatar
What if the engine runs a bit colder? What does that do?
Old Mar 15, 2009 | 11:54 PM
it's not at its max efficiency
rockyboy
Aug 4, 2024 10:35 AM
space_boy
ILX
51
Aug 15, 2017 12:06 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
01CLOwner
Oct 9, 2015 01:07 PM
dlknight
Sep 3, 2015 07:54 PM
