Replacing Ignition Switch
Old Jan 10, 2015 | 01:22 PM
pporto's Avatar
8th Gear
OK, I'm another guy who can't get the steering column housing apart so I can replace the ignition switch. I can't get the right sides apart. The screw that holds the upper and lower together is loose, but I can't get it to fall out and I can't get the sections apart.
Why is it always the last damn screw?
I have a 1996 2.5TL. What a great car, by the way. I bought it new, and I'm still driving it.
Old Jan 10, 2015 | 03:55 PM
pporto's Avatar
8th Gear
OK, I figured that part out. Now I need to know how to detach the key/switch assembly from the steering wheel frame. Or, it looks like if I can get some sort of 90 degree screwdriver thing I could just remove the part of the switch I am replacing (not the part that you put the key in). There is one screw that holds it in place that is in a place that is to tight to get to with a normal length screwdriver.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Skirmich
Sep 15, 2015 06:41 PM
