Removing the rear panel
Can sumone temm why i cant seem to get the rear speaker off...I already unbolted it but the speaker or the rear speaker cover will not come off. Also if u have any info. On how to remove the trunk liner so i can put dynomat . The only thing i can think of if i force it and i dont want to do that wanna keep the damage to a minimal n
'13 Hyundai Sonata
If you haven't taken the speaker cover out then how did you take the screws out. If you are replacing the factory speakers then there is a foam piece underneath it that will stick the speaker to the metal. Just take a knife under the speaker to loosen it up then it should come right out.
Default
Rear speaker covers are held on by 3 bolts. You can access them from the trunk. I had to lay on my back and have my feet hanging out of the trunk. My neighbors laughed at me ![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
After you take the covers off the speakers are held on by 4 screws each. Access that from the back seat, underneath the covers you removed.
98 3.2 Flamenco Black
Getting into the trunk was not as easy...when I put in my subwoofer 9 years ago, nothing to it. When I went in and re-wired my ground tap, sheeettt, I am old! I had all sorts of back ache and sheet! I am old...just to get in and out took my breath away, specially the getting off...I had to ask for somebody's help! What a wooze!
Oakes
Wash & Wax
10-12-2015 11:17 AM
