Rear pass. window
Rear pass. window
Having a problem with my passen. side wind.
When i brought it a month ago it didnt really want to go down. After a few days worked fine for a few weeks. Then started to not go down any more. Worked again. Now it won't go down. It moves maybe 1cm up but that using the rear door switch. When i use the driver door switch it wont move. Any ideas?
i think you need to take apart the switch at the door and test the leads for voltage... start at the cheapest fixes first then go from there...
if you download the manual, it will show you which leads to test for continuity etc... do you have a meter???
clean out all the contacts within the door, that helped my window situation.
They would usually work, sometimes not, sometimes only certain switches...
Remove the door panel and check all the contacts for corrosion or moisture, put some new dielectric grease in there and reassemble.
our windows are usually know to have slow window speed, or in some cases, they get stuck until you "manually" pull it up while you hold the window button.
5cylinder has the right idea. Some members put degreaser in it and it solved the problem.
BoricuaTL
04-08-2016 01:08 PM
ahsm
09-09-2015 08:35 AM
