Problems with wheel nuts
Old Apr 5, 2002 | 12:36 AM
TL12's Avatar
I have Motegi M7 wheels and the bolt holes are very small and everytime I remove or tighten the nuts with the special socket that came with the wheels, it scrapes the inside of the holes and peels off the clearcoat.
Has anyone else had the same problem?
Old Apr 5, 2002 | 09:34 PM
TLBaller's Avatar
hmmm i hope you got the right wheel to fit your car! is your car a 2.5 or 3.2? 2.5 has a bolt pattern of 4x114.3 and 3.2 is 5x114.3. see if your wheels can fit that bolt pattern, if not....return it or sell it
Old Apr 5, 2002 | 10:31 PM
TL12's Avatar
Sorry, I didn't explain my problem well. My wheel fits the studs okay, but the holes for the nuts are very small and the nuts require a special socket to tighten them. Because the socket wiggles a bit, it scrapes the paint when tighten the nuts.
I hope this is a bit clearer.
Old Apr 6, 2002 | 12:56 PM
Din's Avatar
Din
Are you using Tuner lugs? If not maybe you should get some of those.. They should help.
Old Apr 14, 2002 | 11:00 PM
TL12's Avatar
Are Tuner Lugs that ones that are tightened with a hex drive on the inside of the lugs? ............ Thanks!
Old Apr 15, 2002 | 10:49 PM
Din's Avatar
Din
Yes
cycdaniel
Dec 17, 2019 10:58 AM
nanos
Nov 12, 2015 08:41 PM
lland
Oct 4, 2015 04:47 PM
merc009
Oct 3, 2015 12:59 AM
GhostTL09
Sep 19, 2015 01:57 PM
