Please help..
Old Mar 4, 2015 | 09:12 PM
UA2_408's Avatar
5th Gear
Please help..
My 96 3.2 tl seems to get the shivers. Like at times when its at standstill it shakes. I don't have a clue as to why. I recently installed a new transmission, transaxle & engine block. Also in the morning when it gets started it idles. Please help. All info is really appreciated. Thank you.
Old Mar 5, 2015 | 02:17 PM
adventurecrv's Avatar
Sounds like a misfire. How's the fuel filter? Plugs? COPs? Could be numerous things. Have you checked for codes? Loose connector? Did this start right after all your work?
Old Mar 5, 2015 | 06:15 PM
UA2_408's Avatar
5th Gear
My fuel filter is brand new as well. What plugs are you referring to ? Also what does COPs stand for ? No i haven't checked for codes either. What connection are you talking about ?
Old Mar 5, 2015 | 06:20 PM
UA2_408's Avatar
5th Gear
And the shivering started to happen after the new block was installed.
Old Mar 7, 2015 | 07:39 AM
TLin401's Avatar
'13 Hyundai Sonata
Was the car tuned?
Old Mar 8, 2015 | 11:37 PM
UA2_408's Avatar
5th Gear
No the car was not tuned.
Old Mar 8, 2015 | 11:53 PM
Ken1997TL's Avatar
Get a scan tool and get it tuned.
Idle air control valve? PCV?
Old Mar 10, 2015 | 10:46 AM
COP = Coil On Plug. I was referring to the spark plugs. When they replaced the block, they would have had to remove many electrical connectors. Fuel injectors, COPs, etc, etc. Are they all back on properly? Any loose? Any broken wires? Scan tool is a good place to start for sure. The plug for the OBD-II scan tool is under the ashtray....
Where is the code reader port on a 1998 Acura 3.2TL. I have an - Fixya
srika
Technology
Dec 15, 2005 06:41 PM
