PCV Valve?
Old Sep 21, 2004 | 11:20 AM
WolfpackBill's Avatar
TL no more!
PCV Valve?
Does anyone know if our 3.2L engines have a PCV valve. I'm guessing it's an emission equipment so we must have it. So where is it?? I'm planning to run a half a can of SeaFoam down to clean out the engine.
Old Sep 21, 2004 | 12:42 PM
fla-tls's Avatar
On the way!
It's on the back valve cover. It's item 2 in this diagram (Type S motor - but should be the same):
Old Sep 21, 2004 | 12:45 PM
fla-tls's Avatar
On the way!
Sorry - didn't realize you were asking for first gen. It's item 3 on this diagram:
Old Sep 21, 2004 | 01:33 PM
TL no more!
Awesome!! Thanks, bud!!!
Old Sep 21, 2004 | 01:47 PM
fla-tls's Avatar
On the way!
N/P
Old Mar 20, 2005 | 10:47 AM
whatwasthat's Avatar
where do you get diagrams like that? is it from a site?
Old Mar 20, 2005 | 11:18 AM
dubcnea's Avatar
Hurricane Game
yeah, got any for a 2.5??
Old Mar 20, 2005 | 12:10 PM
vanz's Avatar
'97 2.5TL Premium
yeah...and is it easy to change yourself?
Old Mar 20, 2005 | 12:45 PM
UnsanePyro's Avatar
Registered Driver
What the crap is it and what does it do?
Old Mar 20, 2005 | 04:00 PM
cambo's Avatar
OMG! Oh N0ES!
http://www.acuraautomotiveparts.org/
use the menus to find what ur looking for.
Old Aug 26, 2005 | 11:00 AM
GBINKSTER's Avatar
I Changed mine because air was seeping out of the old one. The new one still fizzes the sound of air. Do i have to seal the bottom.
Old Sep 2, 2005 | 10:45 PM
GBINKSTER's Avatar
Bump
Old Sep 7, 2005 | 02:28 PM
GBINKSTER's Avatar
bump. Or maybe i need to fix the whole valve, not just the pcv valve?
Old Sep 14, 2005 | 12:14 PM
Matt97TL2.5's Avatar
It's a one way valve for emissions control. It routes unburned gases back into the intake manifold to be reburned. If it gets clogged, you'll get bad gas mileage and it will eventually hose your cat due to all the extra crap it has to filter. It also keeps sludge buildup in the crankcase down due to the constant airflow.
Old Sep 15, 2005 | 03:02 PM
GBINKSTER's Avatar
O.K. i got a new pcv valve for like 3 bucks, but it didnt fix the noise. When i turn off the engine, there is like a 3 second sound of fizzing, Like air/water is exiting the valve.
Old Sep 15, 2005 | 06:30 PM
longeye23s's Avatar
yea me too, is that somthing we sould be consernd about, i didnt pay ant mind to it couse i thought it sound cool.
Old Sep 16, 2005 | 09:14 PM
GBINKSTER's Avatar
in my opinion (and im only like a grade C mechanic), It doesnt sound right if air or water or air/water is exiting the engine . I heard from some dude who was standing in line next to me at the Acura dealer, that his PCV valve on his Acura Legend was making that fizzing noise, and it cause the idle to go erratic. So yes it should be fixed.
Somone with experience please help us out.
If i changed the PCV valve and it didnt fix the problem, do i have to put some kind of sealant around the bottom of the valve or how do i fix the problem??
Old Nov 25, 2005 | 04:15 PM
zmweaver's Avatar
I'm no grade A mechanic either, but the hose running from the PCV valve is under vacuum. This vacuum system is closed and should not be pulling in air from atmosphere. For some reason the vacuum is overcoming the plastic to rubber seal at the PCV valve. I know they sell some liquid gasket in a tube. It's used for stuff like sealing valve covers. Might be worth a try.
Old Nov 26, 2005 | 10:48 AM
Ken1997TL's Avatar
After some years, your hoses and gaskets will become brittle. So its possible they leak.
Old Nov 27, 2005 | 05:15 PM
zmweaver's Avatar
I pulled my PCV valve off this weekend and the vacuum was very strong. No wonder you have a leak. After-market parts vary slightly in dimension from original equipment. If you are positive you got the right PCV valve and compared it to the original, the rubber gasket the valve fits into is bad. I would advise you remove the valve cover to replace the PCV valve gasket. Don't want to risk getting brittle rubber flakes into your valve assembly. Only other possible solution I can think of is the blue RTV (room temperature vulcanizing) silicone I mentioned. Even if it does work, I would hesitate to ever remove PCV valve after the silicone has cured. Again, due to possible fragments into the valve assembly. Sealing the leak with something like super-glue is not a good idea. Hopefully, for obvious reasons.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
