Park light replacement
Old Apr 6, 2010 | 08:53 PM
Xeion's Avatar
5th Gear
Sorry to post this. A while ago I found a post that described how to replace the park lights that are next to the headlight. I can't for the life of me find that post with the search function so I'm asking in a new thread :-/
I remember someone said there should be a screw that one could unscrew and the bulb should pop out. But I can't find anything of the sort. If someone could supply me with a picture that'd be great.
I have a '97 TL btw.
Old Apr 6, 2010 | 08:59 PM
Go90go's Avatar
大日本帝国
IIRC, 97s and 98s have a metal cover that comes off with a 10mm socket giving easier access to the bulb socket. To remove the bulb socket, just twist it counter-clockwise and it will pop out. To reinstall, turn on the parking lights to give you an easier time seeing the hole, and turn clockwise to lock it in.
~Cheers~
Old Apr 6, 2010 | 09:25 PM
Xeion's Avatar
5th Gear
Thanks a bunch. I'll give it a try when I get a chance.
Old Apr 6, 2010 | 11:19 PM
tmnhs81's Avatar
~Cheers~
Its on drivers side only. Its a small holder for the cruise control vacuum holder thing. By taking it off you have better access to the connector.
Old Apr 7, 2010 | 12:51 AM
Go90go's Avatar
大日本帝国
^ That's what I said.
~Cheers~
Old Apr 7, 2010 | 01:06 AM
tmnhs81's Avatar
But you didn't mention on what side..
Old Apr 7, 2010 | 02:50 PM
myisanog's Avatar
the manual has pictures ... if you just look at the manual you will be good
mada51589
Jan 9, 2025 04:40 PM
TL-Rocket
Apr 29, 2023 02:33 AM
Feb 25, 2020 09:57 AM
wusty23jd
Sep 24, 2015 11:41 AM
brjones9
Sep 3, 2015 07:30 PM
