Oxygen Sensor
Old Sep 23, 2004 | 08:02 PM
mdejonge's Avatar
Oxygen Sensor
How do I install new oxygen sensors on a 1998 TL3.2?
Old Sep 27, 2004 | 12:11 AM
pchen1's Avatar
4th Gear
!998 3.2TL - Bad Oxygen sensor
Which oxygen sensor are you replacing? You will need a special socket fitting which cost about $10-$12 and a long extension (about 10-12 inches) if you are replacing either of the two front primary oxygen sensors. No extension required for the aft oxygen sensor. You may need a little WD40 to help loosen it. Good luck!
I just purchased a 1998 3.2TL with 46K miles and the check Engine light came on and the diagnostic test revailed a bad left front primary oxygen sensor. The question is " Should the oxygen sensor go bad so soon?" especially, since the dealer wants $316 to replace it. All comments will be appreciated.
Old Sep 27, 2004 | 07:44 AM
WBroylesH's Avatar
Isn't that one of the things covered under the 150K extended warranty"?
Old Sep 27, 2004 | 08:27 AM
LDH's Avatar
LDH
I
i don't think it applied to 98's. But its worth a try for the extended emissions warranty
Old Sep 27, 2004 | 09:05 AM
982.5TL's Avatar
All about JDM
I dont think that 98's are covered. I know that my 2.5 isnt, but Im not totally sure about 3.2's. But like u said. Its definately worth a try.
RobbDizzle
Oct 15, 2015 11:16 AM
samson_420
Oct 8, 2015 01:47 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
