overheating problem
Old Oct 7, 2008 | 06:23 PM
tlx82's Avatar
overheating problem
okay this one is weird my car overheat overtime... It is not like i have a leak anywhere but over time it will slowly heat up!! Although I do have to fill up a bit from time to time. I checked my fans and the one on the right is not working. Would that be the problem?
O yea when i am on the freeway and not stuck in traffic the needles will go down
Old Oct 7, 2008 | 11:39 PM
Inspired[RUS]'s Avatar
How do you test your fans?
Old Oct 8, 2008 | 04:25 AM
01tl4tl's Avatar
driver side fan- engine radiator cooling- temp sensor controlled
passenger side fan- ac ON controlled
How is the water pump age? belt condition- tight?
radiator coolant new- less than 5 years old?
radiator dirty inside?
Air bubble in system?
Do a pressure test of the system and make sure no leaks
Check seal on radiator cap
Old Oct 8, 2008 | 10:57 AM
Go90go's Avatar
大日本帝国
^ Good points, also check your hoses for ballooning. If the upper hose is what we call "pregnant", it's time to replace it (and possibly the lower hose) and burp your cooling system to get the air pocket out.
~Cheers~
Old Oct 8, 2008 | 08:39 PM
TexasHonda's Avatar
Slowly overheating is likely a failing thermostat. A new thermostat is easy, cheap repair and has a good probability of fixing your problem. Replace coolant if it's over 2 yrs old.
good luck
Old Oct 10, 2008 | 03:06 AM
tlx82's Avatar
yea i am getting that change out later on today.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
