Noise
Old Oct 8, 2002 | 06:52 PM
Reefers3.2TL's Avatar
Noise
When I make turns my steering is making some weird noises. I checked the power steering fluid and it seems to be fine. Do you guys have any ideas on what it could be??
Old Oct 8, 2002 | 09:33 PM
SamZman's Avatar
Explain these noises a little better. Is this a cracking, popping, grinding, whining..etc.. ?? Does the wheel tug on you around turns? When do you hear the noise? Hard turns? Easy turns? Constant noise?..How many miles does the car have?
I couldn't even guess with just "weird noises"
Old Oct 9, 2002 | 09:13 AM
OK. Medium to hard turns. Its a constant whining but it does not do it all the time.
Old Oct 9, 2002 | 09:54 PM
98tlracer's Avatar
brakes?
Old Oct 10, 2002 | 10:52 PM
SamZman's Avatar
Does it make the noise while the car is not moving but running? I mean can you sit there with the engine running and crank the wheel hard, will it make the whining noise then? If so, I would guess it's powersteering. If it's only at speed it may be cv joints up front? It's hard to guess really. I would suggest taking it to someone who does free estimates such as Midas around here
Old Oct 10, 2002 | 11:05 PM
TLBaller's Avatar
if youre low on power steering fluid, it will be tough to turn the steering wheel. as for a noise when you turn...its not a clicking noise, right? if so, thats normal.. so you say your car makes a "whining" noise??? i wonder what that sounds like.. can you at least identify where the noise is coming from??
Old Oct 11, 2002 | 01:48 PM
AnKiiGrL's Avatar
--Josie--
Hrm....I have noise when I brake sometimes, but other than that, I don't recall having any when I turn the steering wheel.
Yes! Please explain. I like to check mine too just to make sure in case I miss something.
Thanks!
AnKiiGrL-
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
