Need help
Old Nov 2, 2010 | 12:34 PM
DUECEON9ER's Avatar
Need help
Anyone know of a kit that includes inner tie rods, outer tie rods, and sway bar links for the 3.2 or maybe something used for a similar model but also compatible for the 3.2 TL anyone ever try something like this? I need to replace my outer tie rods and might as well replace everything while I'm doing that. I saw this kit onlinehttp://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.m748&item=140 357187436&viewitem=&_trkparms=clkid%3D467292662660 8743527
I contacted the seller and was notified that this will not fit my vehicle yet the compatibility section said it would and now they changed it. Anyone with advice please chime in. Thanks.
Old Nov 2, 2010 | 12:36 PM
KaMLuNg's Avatar
call Tim at OEMAcuraparts and geta pricing on the parts you are thinking about replacing... i wouldn't deal with the headaches of these kits trying to fit on our cars...
IRRC, i know the calipers are interchangable between Legends and 1G 3.2, but i think the knuckle is different...
Old Nov 6, 2010 | 09:40 PM
DUECEON9ER's Avatar
Okay so did some more inspecting and sure enough my stabilizer end links are going also my question is has anyone else dealt with these? What are the common symptoms of end links going out? Just so I can rule it out.
Old Nov 8, 2010 | 07:44 AM
Go90go's Avatar
大日本帝国
A clunking after finishing a turn.
~Cheers~
Old Nov 8, 2010 | 12:11 PM
TexasHonda's Avatar
I just replaced the anti-sway bar bushings on my 2.5TL this weekend. It's an easy job. I did loosen the two large swaybar rubber bearings that support the bar to allow more flexibility when assembling the bushings on each end of the bar. Don't tighten anything until you have nut started on both ends of bushings. There is barely 1mm of bolt thead poking above the last washer to get the nut started.
The following link is for an Acura MDX w/ 3.2 engine. Your outer/inner tie-rods should be similar and tools are probably the same.
http://www.mdxers.org/forums/73-2001...-diy-pics.html
I replaced the boots on my 2.5TL and inspected the inner tie-rods. They appeared to be in good shape.
good luck
