Made progress on LED project... (pix)
Ex-Mod
I did the climate control and the cluster so far. I also made the blinkers in the cluster LEDs but I forgot to take pics. I still have to do the dimmer switch, foglight switch, mirror switch, cruise switch, ashtray, cigarette lighter, & shift plate. Those will be done this week for sure. These LEDs are alot brighter in person and the pics do no justice whatsoever.
Climate Control:
Climate Control:
Ex-Mod
Re: How did you do that
Originally posted by ELA.TL
How did you do that, thats preety tight.
Damn. Looks nice! Did you change all the bulbs in your car too? Like the map light, side door lights, and license plate light? If you haven't you should, it gives your car a more cleaner and luxury look to it. I spent no more than a 100 doing all mines.
Ex-Mod
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Hey 96TL, Can u give me instructions on changing those lights, especially on the climate control and the speedometer! If anything email it to me @ reynoso2299@msn.com. By the way, your car is phat! I really like the way u hook up your car and the fact that u do most of the work. have u installed those Benz turning signal lights yet? I'm still waiting for those pics!
thanks really appreciate it!
Ex-Mod
OK. This is NOT easy to explain but I'll try. I still havent found a way to change the climate control display or the clock YET. I will keep you posted. The bulbs that light up the cluster are just LED based 194/168 bulbs. You can get those from autolites.net or LEDtronics.com. (The LEDtronics ones are much better) There are 5 of those. You also have to change the bulbs on top of the cluster that light up the needles to LEDs. You can also change the blinker bulbs. The climate control and switches are hard to do. You have to modify the factory clip that holds the bulb to hold LEDs. Its pretty annoying to do. Do a search on LEDs posted by Nate for more info on this. BTW, use 1/4 watt 470 ohm resistors on all these LEDs.
Cluster:
5 194/168 based LEDs (Numbers)
2 5mm LEDs (Needles)
2 74 based LEDs (Blinkers)
Climate Control
4 5mm LEDs
2 3mm LEDs
Ashtray
1 74 based LED
Cig. Lighter
1 74 based LED
Shifter plate
You can use 1 74 based LED but it doesnt light up the hole thing. I modified a 74 based socket like the ones the blinker bulbs use and mounted a 5mm LED in there. It works much better but its up to you. If you get a 74 based LED all you have to do is plug it in.
Mirror switch
1 3mm LED
Dimmer switch
1 3mm LED
Cruise Control
2 3mm LEDs
Fog light switch
2 3mm LEDs
Sites for parts:
LEDtronics.com
3mm LEDs - Part No. L121CB1K-3.5Vf ($6.00 x8)
5mm LEDs - Part No. L201CB1K-3.5Vf ($8.00 x6 or x7)*
74 based LED - Part No. WF150-0PB-014V ($9.50 x4 or x5)*
*This depends on how you plan on doing the shift plate. You can use either LED but the 5mm needs to be modified.
Autolites.net
3 packs of 194/168 blue LEDs ($16.50 x 3)
Good luck! I would order a few extra LEDs. I managed to blow 1 out by accident so be careful.
Cluster:
Climate Control
4 5mm LEDs
2 3mm LEDs
Ashtray
1 74 based LED
Cig. Lighter
1 74 based LED
Shifter plate
Mirror switch
1 3mm LED
Dimmer switch
1 3mm LED
Cruise Control
2 3mm LEDs
Fog light switch
2 3mm LEDs
Sites for parts:
LEDtronics.com
Autolites.net
Originally posted by esCarbonie
what did you end up doing? (brand/model of bulbs) can you link us up to a good place to get some?
Received 2,329 Likes
Hey everyone new to this forum, been at Temple of VTEC for a few years though.
I got a question about LED's... does anyone know how/where to do LED gauges like the new Accord/TSX ?
justin7779
12-25-2015 10:33 PM
09-17-2015 09:01 PM
