Loud noise when accelerating
How loud is it getting? And is it in sync with the RPMs? What kind of sound?
It's obviously going to get louder under acceleration (rising RPMs, burning more fuel) but its a mattter of it just being the sound of the fuel burning, or the rods bending
Open up the hood, left hand side towards the headlight. You should see a black plastic box where the air comes in. Make sure its fully attached to get the least noise possible.
Originally Posted by Vincent
Probably muffler issues... After getting my muffler and tips replaced, my car was as quiet as the dead of night.
I just thought it was the VTEC kicking in. I have loud noises to when I accelerate past a certain point.
No VTEC on either engine, though both have a variable intake.
Originally Posted by Mizouse
hmm.. maybe thats whats causing my car to make this noise.. whenever i rev it up to 4-5k right before the tranny shifts to the next gear it kinda makes a "woot" noise (kinda hard to describe it) and then goes into the next gear
Straight from Honda:
VARIABLE INDUCTION SYSTEM
For the 3.2-liter, a boost for both high-end power and low-end torque is provided by a Variable Induction System, similar to that used in the NSX. A unique two-level intake manifold-made of aluminum to save weight-provides three possible paths for air being inducted into the engine. The path is selected by three butterfly valves that are electronically controlled and actuated by intake vacuum. When the engine is running at less than 3300 rpm, air for the two banks of cylinders is strictly separated and is led through the longer of two intake paths for optimum resonance charge effect at low engine speeds. Between 3300 and 3900 rpm, the two larger butterflies open and air flows through the shorter path for best resonance effect in the midrange. Then at 3900 rpm, the third butterfly opens to provide a large plenum serving all cylinders. At this point, the resonance effect is reduced, but an inertia ram tuning effect takes over to boost high-end breathing and power output.
The 2.5 TL inline-5 cylinder engine is tilted to the right, 35 degrees from vertical. This has allowed the engineers to design a manifold with long, tuned intake runners to optimize engine breathing. Based on technology developed for the NSX, the intake manifold is a dual-stage design and increases both low-end torque and high-end horsepower.
Below 5000 rpm, the cylinder is fed by the primary runner. Above 5000 rpm, however, the engine vacuum opens a butterfly valve, allowing the passage of air through a secondary runner. This increases the volume of air entering the combustion chamber and also produces an inertia ram-tuning effect for more complete cylinder filling, increasing both horsepower and torque.
Originally Posted by vanz
I've never even gone above 3500 rpm.
she passed with flying colours. THere is obviously a limit as diriving hard causes more wear and tear, but the more than occasional run up to the redline will help clean out your engine. I'm not sure if they still do, but the old Prosche manuals used to actually recommend taking your car ono the highway once a month and giving it a good run to clean out the carbon deposits.
Originally Posted by veo
Looked under the car today and noticed a little smoke coming out the middle of the muffler. Could it be a hole in the muffler causing loud acceleration?
I had a slight hole in my exhaust manifold and it sounded like an old Atari game.
Originally Posted by Cornflake
I wouldn't want to see the carbon buildup in YOUR engine.... :S It's actually GOOD for an engine to give it a good run once in a while. When I got my car from my dad, I don't think he'd ever gone over 4000 RPM, and as a result, at only 5 years old, it almost failed emissions. Two years later after my somewhat harder drving...
Its good exercise for your car to be pushed just a bit now and then.
BTW, love the avtar."Im so roooonnry, oh so roooonrrryy....."
"How u like that, how u ike it now, Hans BLIX"
you know seafoam does that stuff actually work any good for your car for like cleaning out carbon deposits and stuff??
Originally Posted by vishnus11
its also pretty fun
Originally Posted by LDH
seafoam helps a lot especially if your car has high miles and lots of carbon build up. I convinced my friend to do it in his accord and it made a really big difference. But there is a downside, if the carbon buildup is preventing oil from leaking and you run seafoam it might make it so the oil will leak through. But my accord had 150k the first time I used it and now I have ~165k and I haven't had problems since.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
That shows how much I know about cars.
