light bulb info
First Gen 3.2 TL
light bulb info
hey..wassup everyone.. i've been steadily getting PMs asking which light bulbs i use on my car so i thought i should just post it for all those who might be wondering..
all the parking/signal bulbs are from a japanese company called Polarg (BL-Hybrid).. since my headlamps are jdms, the corner bulb is different from the US version. mine uses a larger bulb, but the US version uses the..
1. Polarg BL-Hybrid #M-4 bulbs in the headlamp corners as well as the corner bumper lamps.
2. the bumper signal lamps i believe uses the Polarg BL-Hybrid #M-2 bulbs. (mine was coverted to a dual filliment setup using the Polarg BL-Hybrid #M-14 bulbs.)
3. the rear license plate lamps use the the Polarg BL-Hybrid #M-6(alittle larger/brighter), but the Polarg BL-Hybrid #M-2 bulbs are the correct size..
4. the headlamps i am currently using is the helios 9000k HID kit, but previously, i used M-tec H-4 bulbs(japanese brand).
5. the factory foglamps are stock h3 bulbs..
6. the aftermarket foglamp kit is a PIAA kit.
7. interior dome lights and door panel lights use the Polarg BL-Hybrid #M-16 bulbs
8. trunk lamp uses the Polarg BL-Hybrid #M-4 bulb..
these are without HIDs..
with HIDs..
hope this helps...
with HIDs..
hope this helps...
u seem to have the same problem as me ...at least judging from the pics u r. i cant get all my bulbs to match colors, like the turn signals and the lights at the bottom n all
Dude Ur Lights Seem To Be On All At Once, What U Use For Ur Front Turn Signals? My Light Looks The Same Excapt For The Turn Signal. It Does Not Matter To Me Course It Only Turns On When Im Turning. But I Do Like The Hid Lights..
Perfect and Greek
question for tlxracer or anyone else-
i would like to upgrade my corner lights to the Polarg M6 bulbs,
they are the same wedge style as stock but are rated at 12V18W instead of 12V5W...
will this work or will i have problems-???--thanks
First Gen 3.2 TL
First Gen 3.2 TL
https://acurazine.com/forums/car-parts-sale-361/wanted-stock-sways-houston-austin-72490/
https://acurazine.com/forums/ramblings-12/pledge-allegiance-73274/
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
